楼主: Petrohunting
石油英语学习点滴帖
     楼主| 发表于 2015-4-22 09:14:09 | 显示全部楼层
     楼主| 发表于 2015-4-27 13:47:30 | 显示全部楼层
    雷军在印度的雷人英语 http://www.ximalaya.com/#/10519556/sound/6564110
     楼主| 发表于 2015-4-30 22:20:49 | 显示全部楼层
    奥巴马2015白宫记者协会晚宴演讲:http://www.ximalaya.com/#/10519556/sound/6568715
     楼主| 发表于 2015-5-13 08:06:30 | 显示全部楼层
    价下跌的6个原因
    1. Iran Returns
    2. Fracking is Not Going Away
    3. OPEC is Idle
    4. Russia Produces More
    5. ISIL's Days are Numbered
    6. No Demand
    音频: http://www.ximalaya.com/#/zhubo/10519556/
     楼主| 发表于 2015-5-29 20:26:57 | 显示全部楼层
    What is S U C C E S S ?
    不错的图解,学习石油英语很适用。
    音频:
    http://www.ximalaya.com/#/10519556/sound/7047940
    (剪自 专业石油英语口语培训课堂录音)
  • 签到天数: 133 天
    发表于 2015-5-30 10:53:51 | 显示全部楼层
    收藏一下。
     楼主| 发表于 2015-6-2 12:32:41 | 显示全部楼层
    High-end:
    being the most expensive and technically sophisticated:
    The use of several high-end software packages made this work easier, providing broader opportunities to evaluate potential attributes in seismic data.
    高端的
     楼主| 发表于 2015-6-10 20:56:36 | 显示全部楼层
    Walther's Law
    Walther's Law of Facies, or simply Walther's Law, named after the geologist Johannes Walther, states that the vertical succession of facies reflects lateral changes in environment. Conversely, it states that when a depositional environment "migrates" laterally, sediments of one depositional environment come to lie on top of another. A classic example of this law is the vertical stratigraphic succession that typifies marine transgressions and regressions.
    瓦尔特定律
     楼主| 发表于 2015-6-12 18:39:01 | 显示全部楼层
     楼主| 发表于 2015-6-13 09:53:52 | 显示全部楼层
    What is the difference between Technique and Technology?
    • Technique is a way or style of doing things, whereas technology is the application of scientific principles behind the working of gadgets.
    • Technology keeps on advancing to make appliances smarter and more efficient.
    • Different people have different techniques of making use of the same technology.
    • Application of science and engineering takes the shape of technology.
    GMT+8, 2026-8-26 13:35 , Processed in 0.049485 second(s), 15 queries .
