楼主: justbetoo
SPE文献及其他文献互助专贴
   关闭 [复制链接]
发表于 2012-4-15 11:52:50 | 显示全部楼层
求:RAFAELROZO, JAVIERPAZE, et a.l Combing acid-and hydraulic- fracturing technologies is the key to successfully stimulating the orito formation[ R]. SPE 104610, preparedfor presentation at the 2007 SPE Hydraulic FracturingTechnology Conference held in College station,Texas, USA, 29- 31January, 2007
点评
请到82楼下载  发表于 2012-4-16 00:01
  • 签到天数: 127 天
    发表于 2012-4-16 00:01:28 | 显示全部楼层
    hliu1114 发表于 2012-4-15 11:52
    求:RAFAELROZO, JAVIERPAZE, et a.l Combing acid-and hydraulic- fracturing technologies is the key to ...
    SPE-104610-MS-P.pdf
    1.89 MB, 下载次数: 8
    售价: 5 阳光币  [记录]
    参与人数 1阳光币 +2 收起 理由
    justbetoo + 2 解疑答惑,帮助他人
  • 签到天数: 171 天
    发表于 2012-4-16 15:53:37 | 显示全部楼层
    求:SPE7977-MS
    Title TRANSIENT PRESSURE BEHAVIOR OF NATURALLY FRACTURED RESERVOIRS
    Authors Mavor, M.J., Chevron Oil Field Research Co.; Cinco-Ley, H., Stanford Univ.
    http://www.onepetro.org/mslib/servlet/onepetropreview?id=00007977
    谢谢,这片已经找到了
  • 签到天数: 171 天
    发表于 2012-4-16 15:56:46 | 显示全部楼层
    求:SPE9293-MS
    Title: DETERMINATION OF FISSURE VOLUME AND BLOCK SIZE IN FRACTURED RESERVOIRS BY TYPE-CURVE ANALYSIS
    Authors: Dominique Bourdet, Alain C. Gringarten, FLOPETROL
    网址:http://www.onepetro.org/mslib/servlet/onepetropreview?id=00009293
    点评
    请到89楼下载  发表于 2012-4-16 22:39
  • 签到天数: 368 天
    发表于 2012-4-16 18:38:33 | 显示全部楼层
    Flow-test Evaluation of Fractured Reservoirs in Recent Trends in Hydrogeology
  • 签到天数: 368 天
    发表于 2012-4-16 18:40:02 | 显示全部楼层
    Determination of Fissure Volume and Block Size in Fractured Reservoirs by Type-curve Analysis
    Well test analysis for fractured reservoir evaluation
    http://www.doc88.com/p-050298120536.html
    http://www.elsevier.com/wps/find/bookdescription.cws_home/504887/description#description
    点评
    第一篇请到89楼下载  发表于 2012-4-16 22:44
  • 签到天数: 368 天
    发表于 2012-4-16 18:51:20 | 显示全部楼层
    Well Test Analysis of Dual-Porosity Systems, Intercepted by Hydraulic Vertical Fractures of Finite Conductivity
    http://www.onepetro.org/mslib/servlet/onepetropreview?id=00018948
    点评
    请到90楼下载  发表于 2012-4-16 22:43
  • 签到天数: 368 天
    发表于 2012-4-16 18:53:56 | 显示全部楼层
    WELL TESTING ANALYSIS IN A DOUBLE POROSITY RESERVOIR
    点评
  • 签到天数: 127 天
    发表于 2012-4-16 22:38:33 | 显示全部楼层
    ouywp56 发表于 2012-4-16 15:56
    求:SPE9293-MS
    Title: DETERMINATION OF FISSURE VOLUME AND BLOCK SIZE IN FRACTURED RESERVOIRS BY TY ...
    00009293.pdf
    1.21 MB, 下载次数: 10
    售价: 5 阳光币  [记录]
    参与人数 1阳光币 +2 收起 理由
    justbetoo + 2
  • 签到天数: 127 天
    发表于 2012-4-16 22:42:53 | 显示全部楼层
    suzhongliang 发表于 2012-4-16 18:51
    Well Test Analysis of Dual-Porosity Systems, Intercepted by Hydraulic Vertical Fractures of Finite C ...
    00018948.pdf
    1.26 MB, 下载次数: 13
    售价: 5 阳光币  [记录]
    参与人数 1阳光币 +2 收起 理由
    justbetoo + 2
    GMT+8, 2026-8-26 16:19 , Processed in 0.064208 second(s), 20 queries .
