楼主: justbetoo
SPE文献及其他文献互助专贴
   关闭 [复制链接]
    2016-2-1 16:13
  • 签到天数: 63 天
    发表于 2013-2-13 21:56:22 | 显示全部楼层
    winner0827 发表于 2013-1-29 10:47
    题目:Analysis of Production Data Using the Beta-Derivative
    SPE136806
    SPE,149361-MS
    SPE-149361-MS-P.pdf (1.09 MB, 下载次数: 1, 售价: 5 阳光币)
    2016-2-1 16:13
  • 签到天数: 63 天
    发表于 2013-2-13 22:12:23 | 显示全部楼层
    weidi 发表于 2013-1-31 10:55
    1、142564-MS    题目:Acid Diversion using Viscoelastic Surfactants: The Effects of Flow Rate and In ...
    3、141298-MS    题目:An Experimental Study of a New VES Acid System: Considering the Impact of CO2 Solubility
    4、128047-PA    题目:Propagation and Retention of Viscoelastic Surfactants Following Matrix-Acidizing Treatments in Carbonate Cores
    SPE-141298-MS-P.pdf (2.04 MB, 下载次数: 1, 售价: 5 阳光币)
    SPE-128047-PA-P.pdf (997.9 KB, 下载次数: 1, 售价: 5 阳光币)
    点评
    多谢!!  发表于 2013-2-19 17:08
  • 签到天数: 115 天
    发表于 2013-2-25 23:34:01 | 显示全部楼层
    作者:Yang, C.; Gu, Y.
    题目:A new method for measuring solvent diffusivity in heavy oil by dynamic pendant drop shape analysis (DPDSA).
    Presented at the Society of Petroleum Engineers (SPE) Annual Technical Conference and Exhibition, Denver, CO, Oct 5-8, 2003; Paper
    SPE 84202.
    求助,谢谢支助。
    点评
    楼下  发表于 2013-2-26 10:33
  • 签到天数: 185 天
    发表于 2013-2-26 10:33:22 | 显示全部楼层
    SPE-84202-PA-P.pdf
    893.02 KB, 下载次数: 1
    售价: 5 阳光币  [记录]
  • 签到天数: 185 天
    发表于 2013-2-28 21:47:40 | 显示全部楼层
    gindar 发表于 2013-1-29 10:54
    求SPE文献
    Jalali-Yazdi, Y.,  and  Ershaghi, I.:  ‘Pressure Transient  Analysis  of Heterogeneous   ...
    我这三篇文献怎么没人能下呢?
    点评
    楼下  发表于 2013-3-1 08:27
  • 签到天数: 185 天
    发表于 2013-3-1 08:27:08 | 显示全部楼层
    0016341——Jalali-Yazdi, Y.,  and  Ershaghi, I.:  ‘Pressure Transient  Analysis  of Heterogeneous  Naturally Fractured  Reservoirs,’  paper  SPE  16341, presented  at the  SPE California Regional Meeting, Ventura,  California, April 8-10, 1987
    00013409——Abdassah D,Ershaghi I.Triple-porosity systems for representing naturally fractured reservoirs[R].SPE
    13409,1986
    00004434——Closmann P,J. The acquifer model for fissured reservoir [J] SPE, 1975, ( 10) : 385~ 398
    00016341.pdf
    580.61 KB, 下载次数: 6
    售价: 5 阳光币  [记录]
    00013409.pdf
    1.28 MB, 下载次数: 6
    售价: 5 阳光币  [记录]
    00004434.pdf
    900.72 KB, 下载次数: 1
    售价: 5 阳光币  [记录]
  • 签到天数: 185 天
    发表于 2013-3-1 10:01:46 | 显示全部楼层
    704038058 发表于 2013-3-1 08:27
    0016341——Jalali-Yazdi, Y.,  and  Ershaghi, I.:  ‘Pressure Transient  Analysis  of Heterogeneous   ...
    多谢多谢,还能给我下一篇吗?http://www.onepetro.org/mslib/se ... iew?id=SPE-002156-A多谢了
    点评
    楼下!  发表于 2013-3-1 15:17
  • 签到天数: 185 天
    发表于 2013-3-1 15:17:32 | 显示全部楼层
    Pressure Transient Analysis of Naturally Fractured Reservoirs with Uniform Fracture Distribution
    SPE-002156-A.pdf
    688.47 KB, 下载次数: 0
    售价: 5 阳光币  [记录]  [购买]
  • 签到天数: 185 天
    发表于 2013-3-1 15:49:55 | 显示全部楼层
    我发现70年代前的文献是免费的,这个我自己下了,不过还是多谢了
  • 签到天数: 368 天
    发表于 2013-3-4 16:01:30 | 显示全部楼层
    http://www.onepetro.org/mslib/se ... iew?id=SPE-90255-PA
    Secondary porosity and permeability of coal vs. gas composition and pressure
    http://www.onepetro.org/mslib/servlet/onepetropreview?id=00016030
    对应助及时者,建议给予奖励。具体办法:应助时间不超过24小时的,可以在价格上增加20%,比如原本卖5个阳光币,现在可以卖6个了。嘿嘿!
    点评
    466L  发表于 2013-3-5 13:01
    GMT+8, 2026-8-26 20:06 , Processed in 0.045538 second(s), 20 queries .
