楼主: Joseph
[开发地质和静态模型] 重奖征集评议:tNav学习笔记
     楼主| 发表于 2018-6-13 09:40:44 | 显示全部楼层
    类似的,40井
    (此处有个小疑问,加载40井的BHP数据会冲掉3井的BHP数据,不知道是不是一个bug,不过也不难处理,就是合并文件:
     楼主| 发表于 2018-6-13 10:05:32 | 显示全部楼层
     楼主| 发表于 2018-6-13 10:23:00 | 显示全部楼层
    算个moipm,输出一个井上估值:
    moipm, Mobile oil in place (Mass)
    补充:
    根据Manual,如下内容也可在Map上体现,
    In tNavigator in the map tree Fluid-in-place the following properties are available:
    • Oil in place (oip) (METRIC: sm 3 , FIELD: stb);
    • Oil in place (Mass) (oipm) (METRIC: ton, FIELD: lb);
    • Mobile oil in place (moip) (METRIC: sm 3 , FIELD: stb);
    • Mobile oil in place (Mass) (moipm) (METRIC: ton, FIELD: lb);
    • Gas in place (gip) (METRIC: sm 3 , FIELD: stb);
    • Gas in place (Mass) (gipm) (METRIC: ton, FIELD: lb);
    • Mobile gas in place (mgip) (METRIC: sm 3 , FIELD: stb).
    These properties can be used in User Arithmetic in User Maps. Their names in brackets should be entered in the Arithmetic Command Line.
    If there is vaporized oil in gas, additional maps will be visualized:
    • Free oil in place (METRIC: sm 3 , FIELD: stb);
    • Mobile Free oil in place (METRIC: sm 3 , FIELD: stb);
    • Vaporized oil in place (METRIC: sm 3 , FIELD: stb);
    • Mobile Vaporized oil in place (METRIC: sm 3 , FIELD: stb).
    If there is dissolved gas in oil, additional maps will be visualized:
    • Free gas in place (METRIC: sm 3 , FIELD: stb);
    • Mobile Free gas in place (METRIC: sm 3 , FIELD: stb);
    • Dissolved gas in place (METRIC: sm 3 , FIELD: stb);
    • Mobile Dissolved gas in place (METRIC: sm 3 , FIELD: stb).
     楼主| 发表于 2018-6-13 10:40:13 | 显示全部楼层
    右键(RMB)可以 Create 增加一个Map,然后双击Map即可修改名字。(我试了Rename,似乎没有起到效果,不确认是否是bug。不过双击真的很实际、很好用。)
     楼主| 发表于 2018-6-13 11:46:48 | 显示全部楼层
    孔隙度当然是不会因为时间步而变化的,但是水饱一类的就需要关注时间步的位置了,因为输出的都是当前时间步的场。
    再加一个Final的SWAP
    (到了这里才看懂了Rename是同时要修改两个内容的,一个是文件表现的名字,还有一个是内部计算用的变量名字“Map3”、“Map4”这样的东西就可以有点儿意义了,容易识别些。很有用的!!)
    再搞搞颜色:
    还可以加分区:
     楼主| 发表于 2018-6-15 08:47:47 | 显示全部楼层
    1-4
    How to Handle Multiple Model Versions
    打开工区,
    找到相对渗透率窗口,
    按照教程对比两个不同工区里相对渗透率的差异:
    然后打开培训工区3,
    这次不同了:
     楼主| 发表于 2018-6-15 09:09:13 | 显示全部楼层
    关掉打开的所有工区。
    这一次从Batch Jobs开始,
     楼主| 发表于 2018-6-15 09:27:08 | 显示全部楼层
    选择Var-1工区,
    (1-4 完。)
     楼主| 发表于 2018-6-15 10:10:18 | 显示全部楼层
    1-5
    How to Load Calculated Results
    Simulation -> Open, 选择 1-5 培训数据中的 m90.data
     楼主| 发表于 2018-6-15 12:18:31 | 显示全部楼层
    然后自己run一个结果:
    算一个差:
    GMT+8, 2026-8-20 04:29 , Processed in 0.036881 second(s), 17 queries .
