查看: 4988|回复: 7
[CMG] 压力变化过大终止模拟
    2012-5-24 10:13
    发表于 2012-3-20 13:27:28 | 显示全部楼层 |阅读模式
                                      G E M   T I M E   S T E P   S U M M A R Y
         Time Step           Time                            Maximum Changes                       Mat    Solver
    ---------------- ----------------- ---------------------------------------------------------  Bal  -----------
           Size Total                        Pressure         Saturation         Composition       Err  Iter/   Cum
    No.   days  iter  Days     Date      Block    psia     Block   Fraction   Block    Fraction    %    Cycl  Fail
      241  60.00    1 1.20e4 2032.12.26   20,1,2  12.76   41,41,2  2.8e-2(w)    1,1,2  3.0e-4( 8) 33e-4  16.0  102
      242w 6.000    1 1.20e4 2033.01.01  41,41,1  2.334     1,1,2  5.1e-3(w)  41,41,2  1.7e-4( 8) 33e-4   9.0  102
      243  60.00    1 1.21e4 2033.03.02   1,21,2  11.97     1,1,2  4.1e-2(w)    1,1,2  -21e-5( 8) 33e-4  19.0  102
      244  60.00    1 1.21e4 2033.05.01  41,22,2  11.47     1,1,2  -37e-3(w)    1,1,2  4.4e-4( 8) 33e-4  17.0  102
      245  60.00    1 1.22e4 2033.06.30  41,21,2  10.98     1,1,2  -55e-3(o)    1,1,2  -57e-5( 8) 33e-4  17.0  102
      246  60.00    1 1.22e4 2033.08.29  22,41,2  10.28     1,1,2  -51e-3(w)    1,1,2  6.4e-4( 8) 33e-4  17.0  102
      247  60.00    1 1.23e4 2033.10.28   21,1,2  9.849     1,1,2  6.3e-2(w)    1,1,2  -73e-5( 8) 33e-4  15.0  102
      248  60.00    1 1.24e4 2033.12.27  41,22,2  9.291    41,1,2  -59e-3(w)    1,1,2  7.7e-4( 8) 33e-4  16.0  102
      249w 5.000    1 1.24e4 2034.01.01    2,2,1  -3.33    41,1,2  5.6e-3(w)   41,1,2  -36e-5( 8) 33e-4   8.0  102
        --- Repeat time step: pressure variation too large
      250  .1512    5 1.24e4 2034.01.01  21,21,5  2042    21,21,5  -.161 (w)  21,21,5  .8008 ( 2) 34e-4   3.8  102
      251  9.4e-2   2 1.24e4 2034.01.01  21,20,5  346.0   21,21,5  .4859 (g)  20,21,5  .1654 ( 2) 33e-4   2.5  102
      252  .2360    2 1.24e4 2034.01.01  20,21,5  456.4   20,21,5  .1145 (o)  21,20,5  .2421 ( 2) 33e-4   3.0  102
      253  .4873    2 1.24e4 2034.01.01  21,21,4  280.1   20,21,5  .5541 (g)  21,21,4  .2576 ( 2) 33e-4   4.0  102
      254  .9458    5 1.24e4 2034.01.02  21,21,5  -451    21,21,4  .5429 (g)  21,19,5  .3742 ( 2) 32e-4   5.8  102
      255  .9458   10 1.24e4 2034.01.03  21,21,5  -313    19,20,5  -.127 (w)  21,19,5  .2478 ( 2) 32e-4   5.9  102
        --- Repeat time step: Unusual pressure in block (    21,21,5 )
      256  .2365    3 1.24e4 2034.01.04  18,21,5  108.3   18,21,5  -25e-3(w)  20,20,4  8.1e-2( 2) 33e-4   4.0  102
        --- Repeat time step: Unusual pressure in block (    21,21,4 )
    我从34年开始注气三采,但是无论怎么改井的限制条件,总会出现压力变化过大而终止模拟的情况,请教各位高人,如果注气量太小生产井就没有任何反应,请教各位高人应该怎么办
  • 签到天数: 18 天
    发表于 2012-3-20 13:47:08 | 显示全部楼层
    请简单介绍一下你的模型
  • 签到天数: 259 天
    发表于 2012-3-20 14:19:44 | 显示全部楼层
    bhp 控制的同时;wi变大,wi参考下,可调到几万,有模板。。。bhp不能超过破裂压力!wi可以多选几个网格,方便注气!
  • 签到天数: 259 天
    发表于 2012-3-20 14:21:30 | 显示全部楼层
      *WELL 1 'Injector 1' *VERT 1 1
       *INJECTOR *MOBWEIGHT 'Injector 1'
       *INCOMP WATER  1.0  0.0
       *TINJW 450
       QUAL .7
       *OPERATE      *BHP   1000     ** Starting BHP is 1000 psi
       *OPERATE *MAX *STW   1000     ** Maximum water rate is 1000 BPD
       *PERFV 'Injector 1'  **  k   wi   wi = 0.007082 *k * h / ln(0.5 * re / rw)
                    4   78075.37 ** 88
                    3   39037.68 ** 44
                    2   97594.21 **110
                    1  195188.43 **220
    用wi控制注入量,压力限制范围。。。
    2012-5-24 10:13
     楼主| 发表于 2012-3-20 15:28:05 | 显示全部楼层
    soi 发表于 2012-3-20 13:47
    请简单介绍一下你的模型
    是这样子的,41*41*10的机理模型,每层厚10ft,一采是加了底水,13年;二采注水,21年;三采是注CO2驱替。问题就出在三采上面,注气量太小达不到混合压力,没有任何oil response,出气量太大就会出现上面的问题而终止模型运行。求版主指点一下啊啊!
    2012-5-24 10:13
     楼主| 发表于 2012-3-20 15:34:52 | 显示全部楼层
    jinzi1216 发表于 2012-3-20 14:19
    bhp 控制的同时;wi变大,wi参考下,可调到几万,有模板。。。bhp不能超过破裂压力!wi可以多选几个网格,方 ...
    十分感谢~~,看过您对另一个帖子的回复,也是有关WI,是有关调整曲线平滑的。我的模型由于压力变化太大,尝试过用numerical里的设置解决但是未遂,只能用wi来解决么?
    2012-5-24 10:13
     楼主| 发表于 2012-3-20 15:37:46 | 显示全部楼层
    请简单介绍一下你的模型
    这个是我GEM模型的的dat文件~~
    Depletion Mode(41 41).zip
    3.33 KB, 下载次数: 15
  • 签到天数: 259 天
    发表于 2012-3-20 19:29:23 | 显示全部楼层
    您可以试试。。。
    GMT+8, 2026-8-22 04:01 , Processed in 0.041069 second(s), 23 queries .
