楼主: 阔叶梧桐
[已完成] 公司酸化产品翻译,30页。
  • 签到天数: 97 天
    发表于 2013-2-13 23:30:46 | 显示全部楼层
    翻译什么的还是比较简单吧。
  • 签到天数: 1059 天
    发表于 2013-2-25 09:06:48 | 显示全部楼层
    进来看看
  • 签到天数: 65 天
    发表于 2013-3-23 22:42:05 | 显示全部楼层
    看看神马东西
  • 签到天数: 1500 天
    发表于 2013-7-29 08:48:01 | 显示全部楼层
  • 签到天数: 401 天
    发表于 2013-8-16 15:23:36 | 显示全部楼层
    三十页,就四天??
  • 签到天数: 3 天
    发表于 2013-8-26 10:22:31 | 显示全部楼层
    没准可以帮上忙!
  • 签到天数: 12 天
    发表于 2013-8-29 20:37:37 | 显示全部楼层
  • 签到天数: 18 天
    发表于 2013-11-7 11:52:34 | 显示全部楼层
    1, product overview
    Any metal surface are composed of electrode through the metal body forms a short circuit, when the metal is exposed to acid, partial cell began and result the metal into the corrosion product and material properties of metal material.
    Corrosion inhibitor can reduce the acidification process of acid on the contact head, tubing and any other metal corrosive chemicals, by affecting the anode and cathode corrosion cells reacted to the corrosion inhibition.
    3, the use of methods
    This product is evenly dispersed in acid, acid and other additives have good compatibility, convenient field use, in the preparation of acid, in accordance with the design requirements of the proportion to the acid liquid can be.
    固控设备gukong.xakx.com    solids control
  • 签到天数: 5 天
    发表于 2014-6-22 15:24:58 | 显示全部楼层
    雁过留毛
  • 签到天数: 460 天
    发表于 2014-7-4 13:34:23 来自阳光石油论坛手机版 | 显示全部楼层
    学习一下
    GMT+8, 2026-8-7 02:11 , Processed in 0.042080 second(s), 14 queries .
