查看: 786|回复: 0
books
发表于 2014-4-2 20:18:48 | 显示全部楼层 |阅读模式
books
A-Bayesian-trans-dimensional-approach-for-the-fusion-of-multiple-geophysical-dat.pdf
3.81 MB, 下载次数: 7
A-new-extension-of-seismic-instantaneous-frequency-using-a-fractional-time-deriv.pdf
1.91 MB, 下载次数: 7
A-new-texture-based-operator-for-edge-enhancement-of-potential-field-data_2013_J.pdf
2.31 MB, 下载次数: 14
An-implementation-of-differential-evolution-algorithm-for-inversion-of-geoelectr.pdf
3.77 MB, 下载次数: 9
Application-of-balanced-edge-detection-filters-to-estimate-the-location-paramete.pdf
2.76 MB, 下载次数: 7
Application-of-the-Brewster-angle-to-quantify-the-dielectric-properties-of-groun.pdf
2.27 MB, 下载次数: 8
Applications-of-ground-penetrating-radar-(GPR)-in-bridge-deck-monitoring-and-ass.pdf
3.58 MB, 下载次数: 8
A-procedure-to-reduce-side-lobes-of-reflection-wavelets-A-contribution-to-low-fr.pdf
5.27 MB, 下载次数: 7
Assessment-of-an-ancient-bridge-combining-geophysical-and-advanced-photogrammetr.pdf
5.04 MB, 下载次数: 8
A-three-dimensional-approach-for-tracking-cracks-in-bridges-using-GPR_2013_Journ.pdf
1.73 MB, 下载次数: 8
AVO-inversion-based-on-generalized-extreme-value-distribution-with-adaptive-para.pdf
3.19 MB, 下载次数: 7
Calculation-of-Rayleigh-wave-phase-velocities-due-to-models-with-a-high-velocity.pdf
775.57 KB, 下载次数: 1
Characterization-of-a-dismissed-landfill-via-electrical-resistivity-tomography-a.pdf
3.01 MB, 下载次数: 8
Clay-content-evaluation-in-soils-through-GPR-signal-processing_2013_Journal-of-A.pdf
1.45 MB, 下载次数: 8
Cylindrical-Wave-Approach-for-electromagnetic-scattering-by-subsurface-metallic-.pdf
548.45 KB, 下载次数: 1
Detection-of-gas-and-water-using-HHT-by-analyzing-P--and-S-wave-attenuation-in-t.pdf
2.29 MB, 下载次数: 9
Detection-of-subsurface-metallic-utilities-by-means-of-a-SAP-technique-Comparing.pdf
1.38 MB, 下载次数: 12
Editorial-Board_2013_Journal-of-Applied-Geophysics.pdf
62.67 KB, 下载次数: 1
Editorial-Board_2013_Journal-of-Applied-Geophysics_1.pdf
33.33 KB, 下载次数: 1
Editorial-Board_2013_Journal-of-Applied-Geophysics_2.pdf
33.29 KB, 下载次数: 1
Electromagnetic-divergence-correction-for-3D-anisotropic-EM-modeling_2013_Journa.pdf
1.78 MB, 下载次数: 14
Estimation-of-in-situ-density-and-moisture-content-in-HMA-pavements-based-on-GPR.pdf
1.13 MB, 下载次数: 13
Evidence-that-bio-metallic-mineral-precipitation-enhances-the-complex-conductivi.pdf
1.52 MB, 下载次数: 14
Fast-seismic-horizon-reconstruction-based-on-local-dip-transformation_2013_Journ.pdf
1.57 MB, 下载次数: 6
Field-and-synthetic-experiments-for-virtual-source-crosswell-tomography-in-verti.pdf
4.47 MB, 下载次数: 7
Frequency-dependent-electric-properties-of-homogeneous-multi-phase-lossy-media-i.pdf
1.41 MB, 下载次数: 12
From-Bayes-to-Tarantola-New-insights-to-understand-uncertainty-in-inverse-proble.pdf
1.32 MB, 下载次数: 0
Fuzzy-classifier-based-support-vector-regression-framework-for-Poisson-ratio-det.pdf
590.1 KB, 下载次数: 0
Fuzzy-ruling-between-core-porosity-and-petrophysical-logs-Subtractive-clustering.pdf
549.59 KB, 下载次数: 0
Geoelectrical,-strain-and-tilt-investigations-of-hydrological-processes-at-the-b.pdf
1.5 MB, 下载次数: 0
GPR-abilities-in-investigation-of-the-pavement-transversal-cracks_2013_Journal-o.pdf
2.43 MB, 下载次数: 0
GPR-spectral-analysis-for-clay-content-evaluation-by-the-frequency-shift-method_.pdf
1.49 MB, 下载次数: 0
Ground-Penetrating-Radar-(GPR)-attribute-analysis-for-archaeological-prospection.pdf
3.3 MB, 下载次数: 0
Imaging-weak-zones-in-the-foundation-using-frequency-domain-attenuation-tomograp.pdf
2.06 MB, 下载次数: 0
Improving-airborne-strapdown-vector-gravimetry-using-stabilized-horizontal-compo.pdf
2.18 MB, 下载次数: 0
Laplace-domain-full-waveform-inversion-using-irregular-finite-elements-for-compl.pdf
1.91 MB, 下载次数: 0
Localization-and-de-noising-seismic-signals-on-SASW-measurement-by-wavelet-trans.pdf
1.78 MB, 下载次数: 0
Magnetic-properties-and-heavy-metal-pollution-of-soils-in-the-vicinity-of-a-ceme.pdf
506.99 KB, 下载次数: 0
Multi-parameter-nonlinear-inversion-with-exact-reflection-coefficient-equation_2.pdf
3.69 MB, 下载次数: 0
Numerical-aspects-of-EGM08-based-geoid-computations-in-Fennoscandia-regarding-th.pdf
1.16 MB, 下载次数: 0
Possibilities-of-ground-penetrating-radar-usage-within-acceptance-tests-of-rigid.pdf
5.19 MB, 下载次数: 0
Preface-to-the-Special-Issue-on-“Ground-Penetrating-Radar-for-nondestructive-ev.pdf
110.29 KB, 下载次数: 0
Publisher's-Note_2013_Journal-of-Applied-Geophysics.pdf
80.06 KB, 下载次数: 0
Seismic-response-of-adjacent-filled-parallel-rock-fractures-with-dissimilar-prop.pdf
733.63 KB, 下载次数: 0
The-bedrock-electrical-conductivity-map-of-the-UK_2013_Journal-of-Applied-Geophysics.pdf
2.58 MB, 下载次数: 7
The-importance-of-including-conductivity-and-dielectric-permittivity-information.pdf
1.74 MB, 下载次数: 8
The-use-of-the-ARP-system-to-reduce-the-costs-of-soil-survey-for-precision-vitic.pdf
2.17 MB, 下载次数: 7
Three-dimensional-interpretation-considering-the-static-and-the-sea-effects-of-m.pdf
3.47 MB, 下载次数: 7
Tilt-angle-interpretation-of-dipping-fault-model_2013_Journal-of-Applied-Geophysics.pdf
1.52 MB, 下载次数: 7
Time-domain-spectral-induced-polarization-of-disseminated-electronic-conductors-.pdf
1.27 MB, 下载次数: 7
Understanding-the-fracture-role-on-hydrocarbon-accumulation-and-distribution-usi.pdf
2.2 MB, 下载次数: 16
Vertical-and-horizontal-distribution-of-magnetic-susceptibility-and-metal-conten.pdf
1.68 MB, 下载次数: 9
GMT+8, 2026-8-20 08:42 , Processed in 0.041346 second(s), 23 queries .
