查看: 2661|回复: 4
[ECLIPSE] ecl 运行了之后的warning和1个error,请教高手指点,求如何解决?
  • 签到天数: 501 天
    发表于 2015-5-30 10:53:04 | 显示全部楼层 |阅读模式
    10阳光币
    1.Generating the grid connections for well 66-30H: The connection to the cell (126,111,15) has been ignored because the connected
    2.Some completions on well 76-13 or one of it's laterals are invalid. Connections may not be as expected
    3.Hydr. Frac ; Hydr Frac 1 is not in a flow path and has not been exported to the simulator
    4.Two overlapping hydraulic fractures. Hydraulic Fracture 'Hydr Frac 2' in well '66-30H' and hydraulic fracture 'Hydr Frac 3' in well '66-30H'. Transmissibility multipliers in overlapping regions will be the product of multipliers generated by both fractures in these regions.
    5.History rate control rules: WEFAC values of 0.0 were defaulted to 1.0.
    6. Failed to determine the idle time for the cores on the machine (failed to execute 'wmic /output:"wmic_output_eclrun_20150530015131016" /interactive:OFF path Win32_PerfFormattedData_PerfOS_Processor get Name, PercentIdleTime' command. Therefore the run will not benefit from setting processor affinity. To disable Affinity, set 'AffinityOnWindows' to 'false' in the config file (see ECLRUN manual for more details).
    7. WELL 80-13 CONNECTS WITH A DEAD BLOCK ( 173 68 14). THIS CONNECTION WILL BE IGNORED.
    8. CONNECTION DATA FOR WELL 66-30H IS MISSING. THE CONNECTIONS MUST BE DEFINED USING KEYWORD COMPDAT BEFORE THE WELL CONTROL KEYWORD (E.G. WCONPROD). SHUTTING WELL.
    9.WELL 66-30H HAS NO CONNECTI1.ONS WITH THE GRID. SET THE CONNECTION DATA.
    10. * WELL 78-56H HAS CHANGED TO * * CONTROL BY BOTTOM HOLE PRESSURE * * FROM TIME 912.00 DAYS . *
    11.WELL 82-25H CONNECTS WITH A DEAD BLOCK ( 151 56 11). THIS CONNECTION WILL BE IGNORED.
    12.THE WELL BORE DIAMETER MUST BE SET IN THE CONNECTION DATA FOR WELL 78-30H1 IF THE CONNECTION TRANSMISSIBILITY FACTOR IS NOT ENTERED
  • 签到天数: 265 天
    发表于 2015-5-31 11:08:32 | 显示全部楼层
    大小写混用,这是哪个地方提示的信息?PRT文件中的?
    回复
  • 签到天数: 501 天
     楼主| 发表于 2015-5-31 15:04:52 | 显示全部楼层
    恩,是,运行完提示的
    回复
  • 签到天数: 501 天
     楼主| 发表于 2015-5-31 15:06:07 | 显示全部楼层
    分析下是大致什么问题,一般从哪个角度解决就行,谢谢
    回复
  • 签到天数: 229 天
    发表于 2017-3-15 22:40:54 | 显示全部楼层
    请问这个问题解决了么?
    回复
    GMT+8, 2026-5-21 04:50 , Processed in 0.045824 second(s), 22 queries .
