查看: 3558|回复: 2
[其他] Repeat time step: unusual pressure in block: 94501 ( 1,1,8M )
  • 签到天数: 157 天
    发表于 2015-3-24 16:23:39 | 显示全部楼层 |阅读模式
    求助大神,我的GEM模型中预先给定了每个网格的压力,但在计算的时候总是个别网格压力为负值,而我回去看压力明明是正值,是什么原因呢?
    log文件部分结果如下:
    ===================== SUMMARY (from subroutine: INDATA) ======================
      Error summary before initialization ...
      Will terminate if data errors have been found.
        0 Warning messages.    0 Error messages.
    *** End of data input
        GEM Dynamic Allocations:            660638 (kB)
        Pointer-based Allocations:           18184 (kB)
        Well Management Allocations:           366 (kB)
        Final Grid-based Allocations:       172675 (kB)
        Current Total Memory Allocation:    851864 (kB)
                                               832 (MB)
    *** Begin simulation ...
        Jacobian-based Allocations:         395675 (kB)
        Current Total Memory Allocation:   1247540 (kB)
                                              1219 (MB)
        --- Repeat time step: unusual pressure in block: 94501 ( 1,1,8M )
    1
                                             G E M   T I M E   S T E P   S U M M A R Y
         Time Step            Time                                Maximum Changes                            Mat  Cum    Solver
    ----------------- ----------------- -----------------------------------------------------------------   Bal  time ----------
           Size Newton                        Pressure            Saturation             Composition         Err  step Iter/  Cum
    No.   days  cycls  Days     Date       Block      kpa     Block      Fraction      Block     Fraction    %   cuts  Cycl Fail
        1  5.0e-3   6  5.0e-3 2015.01.01    300,24,1F -48.9     129,23,8M -18e-3(w)       1,1,1M       ( 1) 18e-9    1   7.7    0
    ================= FATAL ERROR (from subroutine: GRCNC4_SIM) ==================
      Fatal Error occurred in Grid Module.
      Contact CMG.
         0 Warning messages.    2 Error messages.
      Contact CMG.
      Terminating simulation: Fatal error.
      End of Simulation: Abnormal Termination
    发表于 2016-11-17 12:41:50 | 显示全部楼层
    ===================== WARNING (from subroutine: RK4ST2) ======================
      Stepsize is numerically equal to zero;
      Set yout = yin and return .
      Line: 427   File Name: F:\ShaleOil\CMG_Unconventional Oil_wells_HFDrcy.dat
    ===================== WARNING (from subroutine: CONDPT) ======================
      Low-accuracy flag encountered in mass-consistent initialization
      Integration within the range of tabulated depths.
    ===================== WARNING (from subroutine: WMWTIN) ======================
      Default action for monitor *BHP of Well no. 1 ('Production')
      is to shut the well.
      Line: 436   File Name: F:\ShaleOil\CMG_Unconventional Oil_wells_HFDrcy.dat
       --- Repeat time step: unusual pressure in block: 1868 ( r15,20 )
       --- Repeat time step: unusual pressure in block: 1873 ( r15,20 )
       --- Repeat time step: pressure variation too large, block: 1873 ( r15,20 )    4946.    psia
                                         G E M   T I M E   S T E P   S U M M A R Y ====================================================================================================================
    ----------------- ----------------- ---------------------------------------------------------  Bal  time -----------
    No.   days  cycls  Days     Date      Block    psia     Block   Fraction   Block    Fraction    %   cuts  Cycl  Fail
        1  1.8e-4   7  1.8e-4 2016.11.16   r15,20  -2.2e3   r15,20  1.3e-3(w)   r15,20  3.7e-4( 2) 97e-9    5   1.4    0
       2  1.1e-4   2  3.0e-4 2016.11.16   r15,20  -733     r15,20  -39e-5(o)   r15,20  1.3e-4( 2) 10e-8    5   1.0    0
       3  2.3e-4   2  5.3e-4 2016.11.16   r15,20  -805     r15,20  4.8e-4(w)   r15,20  1.4e-4( 2) 12e-8    5   1.0    0
       --- Repeat time step: program failed to converge
       4  2.1e-4  14  7.4e-4 2016.11.16   r15,20  -541     r15,20  -27e-3(o)   r15,20  9.1e-4( 2) 84e-9    6   1.0    0
    发表于 2016-11-17 13:00:59 | 显示全部楼层
    help please how to solve the "repeat time step" error
    Thanks
    GMT+8, 2025-5-11 12:46 , Processed in 0.048701 second(s), 22 queries .
