查看: 1241|回复: 4
[ECLIPSE] 黑油模型导入流线模块空跑,出现下面问题,请问怎么调?
  • 签到天数: 454 天
    发表于 2014-12-16 17:22:42 | 显示全部楼层 |阅读模式
    2阳光币
    Type        Date        Time        Description
    Error        1/5/2011        0.000         PVTO SHOULD ONLY BE USED IF MODEL HAS LIVE OIL WITH DISSOLVED GAS
    Warning        1/5/2011        0.000         SPURIOUS DATA BEFORE PVDG KEYWORD 0 0 1.0467 6.76 / 13 20 1.1175 5.25 / 20 35 1.1274 4.33 / 27 50 1.1393 3.9 / 34 65 1.1497 3.63 / 38 81 1.1601 3.54 117.1 1.152 3.99 / /
    Warning        1/5/2011        0.000         SPURIOUS DATA BEFORE SWOF KEYWORD 0 0 1 1* 0.023 0.0044 0.83 1* 0.046 0.0195 0.65 1* 0.069 0.058 0.48 1* 0.092 0.12 0.35 1* 0.115 0.185 0.23 1* 0.138 0.28 0.11 1* 0.161 0.42 0.04 1* /
    Warning        1/5/2011        0.000         SPURIOUS DATA BEFORE REGIONS KEYWORD 0.399 0 1 0.0151 0.422 0.0026 0.83 0.0057 0.445 0.0051 0.66 0.0031 0.468 0.008 0.49 0.0021 0.491 0.011 0.34 0.0015 0.514 0.014 0.216 0.0011 0.537 0.021 0.17 0.00086 0.56 0.03 0.13 0.0007 /
    Error        1/5/2011        0.000         OIL PVT DATA NOT SPECIFIED
    Error        1/5/2011        0.000         EQLNUM FOR CELL ( 46, 27, 12) IS 2 WHICH IS TOO LARGE ( GT 1) OR SMALL ( LT 1)
    Error        1/5/2011        0.000         EQLNUM FOR CELL ( 44, 28, 12) IS 2 WHICH IS TOO LARGE ( GT 1) OR SMALL ( LT 1)
    Error        1/5/2011        0.000         EQLNUM FOR CELL ( 45, 28, 12) IS 2 WHICH IS TOO LARGE ( GT 1) OR SMALL ( LT 1)
    Error        1/5/2011        0.000         EQLNUM FOR CELL ( 46, 28, 12) IS 2 WHICH IS TOO LARGE ( GT 1) OR SMALL ( LT 1)
    Error        1/5/2011        0.000         EQLNUM FOR CELL ( 43, 29, 12) IS 2 WHICH IS TOO LARGE ( GT 1) OR SMALL ( LT 1)
    Error        1/5/2011        0.000         EQLNUM FOR CELL ( 44, 29, 12) IS 2 WHICH IS TOO LARGE ( GT 1) OR SMALL ( LT 1)
    Error        1/5/2011        0.000         EQLNUM FOR CELL ( 45, 29, 12) IS 2 WHICH IS TOO LARGE ( GT 1) OR SMALL ( LT 1)
    Error        1/5/2011        0.000         EQLNUM FOR CELL ( 46, 29, 12) IS 2 WHICH IS TOO LARGE ( GT 1) OR SMALL ( LT 1) STOP LIMIT REACHED ON ERROR OUTPUTS
    Error        1/5/2011        0.000         EQLNUM FOR CELL ( 47, 29, 12) IS 2 WHICH IS TOO LARGE ( GT 1) OR SMALL ( LT 1)
    Error        1/5/2011        0.000         RUN STOPPED BECAUSE NUMBER OF ERRORS EXCEEDS MAXIMUM PERMITTED VALUE ( 10). SEE MESSAGES KEYWORD
    06版,黑油模型导入流线模块运行,空跑NOSIM出现下面的问题,请问怎么调?
    最佳答案
    查看完整内容
    我只做过最简单的油水两相流线模型,PVTO改为PVDO,分区有些问题,检查头文件设置或者initialization部分,一起学习吧!
  • 签到天数: 1073 天
    发表于 2014-12-16 17:22:43 | 显示全部楼层
    参与人数 1阳光币 +10 收起 理由
    justbetoo + 10 解疑答惑,帮助他人
    回复
  • 签到天数: 454 天
     楼主| 发表于 2014-12-17 08:57:53 | 显示全部楼层
    六月雪 发表于 2014-12-17 00:14
    我只做过最简单的油水两相流线模型,PVTO改为PVDO,分区有些问题,检查头文件设置或者initialization部分, ...
    谢谢了啊。
    回复
  • 签到天数: 454 天
     楼主| 发表于 2014-12-17 08:59:58 | 显示全部楼层
    分区什么问题啊?
    回复
  • 签到天数: 265 天
    发表于 2014-12-17 13:48:55 | 显示全部楼层
    先从警告看吧,很多黑油的关键字流线不识别,所有参数都不太对。ERROR是已经出错了。
    参与人数 1阳光币 +1 收起 理由
    yg137760337 + 1 谢谢了啊。我问我师傅
    回复
    GMT+8, 2025-12-18 04:01 , Processed in 0.061794 second(s), 20 queries .
