查看: 1758|回复: 3
[ECLIPSE] 06版RUN 没有问题,但是导入11版就各种问题?要修改哪些?
  • 签到天数: 454 天
    发表于 2014-12-5 13:43:29 | 显示全部楼层 |阅读模式
    2阳光币
    Type        Date        Time        Description
    Message        1/5/2011        0.000         CHECKING FOR LICENSES
    Message        1/5/2011        0.000         THE MEMORY REQUIRED TO PROCESS THE GRID SECTION IS 211989 KBYTES
    Message        1/5/2011        0.000         NEITHER OLDTRAN,OLDTRANR NOR NEWTRAN SPECIFIED TRANSMISSIBILITIES TO BE CALCULATED USING NEWTRAN
    Message        1/5/2011        0.000         71 NON-NEIGHBOUR CONNECTIONS PRESENT
    Warning        1/5/2011        0.000         LEFT HANDED GRIDS MAY NOT BE SUPPORTED IN ALL PRE AND POST PROCESSORS
    Warning        1/5/2011        0.000         THE GRID APPEARS TO BE LEFT HANDED, BUT IS SPECIFIED IN GDORIENT AS RIGHT HANDED. ENSURE GDORIENT IS CORRECTLY DEFINED.
    Message        1/5/2011        0.000         NUMBER OF ACTIVE CELLS IS 11627
    Message        1/5/2011        0.000         THE MEMORY REQUIRED TO PROCESS THE SOLUTION SECTION IS 215368 KBYTES
    Message        1/5/2011        0.000         58670 CHARACTER VARIABLES USED
    Warning        1/5/2011        0.000         A CELL HAS BEEN DETECTED IN AQUANCON THAT HAS AN ACTIVE CELL ON ITS AQUIFER FACING SIDE. THIS CELL WILL NOT BE CONNECTED. A FULL LIST OF CELLS CAN BE OBTAINED USING OPTIONS(99). IN ORDER TO CONNECT THESE CELLS SET ITEM 11 OF AQUANCON.
    Message        1/5/2011        0.000         AQUIFER 1 HAS 521 CONNECTIONS IN THE GLOBAL GRID
    Message        1/5/2011        0.000         AQUIFER 2 HAS 89 CONNECTIONS IN THE GLOBAL GRID
    Comment        1/5/2011        0.000         THE MINIMUM VALUE FOR NCAMAX IN THE AQUDIMS KEYWORD IN RUNSPEC IS 521
    Warning        1/5/2011        0.000         UNRECOGNISED MNEMONIC RPTRST IN DATA FOR KEYWORD RPTSCHED IS IGNORED
    Warning        1/5/2011        0.000         UNRECOGNISED MNEMONIC M1 IN DATA FOR KEYWORD RPTSCHED IS IGNORED
    Warning        1/5/2011        0.000         UNRECOGNISED MNEMONIC M4F IN DATA FOR KEYWORD RPTSCHED IS IGNORED
    Warning        1/5/2011        0.000         UNRECOGNISED MNEMONIC 52 IN DATA FOR KEYWORD RPTSCHED IS IGNORED
    Warning        1/5/2011        0.000         UNRECOGNISED MNEMONIC 44 IN DATA FOR KEYWORD RPTSCHED IS IGNORED
    Warning        1/5/2011        0.000         SPURIOUS DATA BEFORE WELSPECS KEYWORD /
    Error        1/5/2011        0.000         NO WELLS MATCH THE NAME M1 IN THE CONNECTION DATA KEYWORD COMPDAT.
    Error        1/5/2011        0.000         NO WELLS MATCH THE NAME M1 IN THE CONNECTION DATA KEYWORD COMPDAT. STOP LIMIT REACHED ON ERROR OUTPUTS
    Error        1/5/2011        0.000         RUN STOPPED BECAUSE NUMBER OF ERRORS EXCEEDS MAXIMUM PERMITTED VALUE ( 10). SEE MESSAGES KEYWORD
  • 签到天数: 265 天
    发表于 2014-12-5 15:04:31 | 显示全部楼层
    是DATA文件在06计算没问题,然后用2011计算出的问题?还是导入2011的Office后再计算出的问题?
    回复
  • 签到天数: 454 天
     楼主| 发表于 2014-12-5 15:09:31 | 显示全部楼层
    06 版 RUN  没有 任何问题, 导入 2011就出现 以上的 问题,这个 解决不了。感觉 很复杂,11版的 有些关键字 还得 自己写, 不知道除了 06版,有哪些 能看 流线 模型的 版本 方便 实用。你用的哪个版本?
    回复
  • 签到天数: 265 天
    发表于 2014-12-5 15:12:47 | 显示全部楼层
    是导入2011的Office里然后再计算的么?06和11有些关键字的参数可能差别比较大。建议还是用11的吧,速度要比06的快。
    回复
    GMT+8, 2025-12-18 03:59 , Processed in 0.194847 second(s), 18 queries .
