查看: 758|回复: 1
很全的英语短语,防止你英文退化
    发表于 2014-11-24 22:57:48 | 显示全部楼层 |阅读模式
    1. a big headache令人头痛的事情
    2. a fraction of 一部分
    3. a matter of concern 焦点
    4. a series of 一系列,一连串above all 首先,尤其是
    5. absent from不在,缺席
    6. abundant in富于
    7. account for 解释
    8. accuse sb. of sth.控告
    9. add to增加(add up to)
    10. after all 毕竟,究竟
    11. agree with同意
    12. ahead of time / schedule提前
    13. ahead of 在...之前(ahead of time 提前)
    14. alien to与...相反
    15. all at once 突然,同时
    16. all but 几乎;除了...都
    17. all of a sudden 突然
    18. all over again 再一次,重新
    19. all over 遍及
    20. all right 令人满意的;可以
    21. all the same 仍然,照样的
    22. all the time 一直,始终
    23. angry with sb. at/about sth.生气,愤怒
    24. anxious about/for忧虑,担心
    25. anything but 根本不
    26. apart from 除...外(有/无)
    27. appeal to 吸引,申诉,请求
    28. applicable to适用于
    29. apply to适用
    30. appropriate for/to适当,合适
    31. approximate to近似,接近
    32. apt at聪明,善于
    33. apt to易于
    34. around the clock夜以继日
    35. as a matter of fact 实际上
    36. as a result(of) 因此,由于
    37. as a rule 通常,照例
    38. as far as ...be concerned 就...而言
    39. as far as 远至,到...程度
    40. as follows 如下
    41. as for 至于,关于
    42. as good as 和...几乎一样
    43. as if 好像,防腐
    44. as regards 关于,至于
    45. as to 至于,关于
    46. as usual 像平常一样,照例
    47. as well as 除...外(也),即...又
    48. as well 同样,也,还
    49. ashamed of羞愧,害臊
    50. aside from 除...外(还有)
    51. ask for the moon异想天开
    52. at a loss 茫然,不知所措
    53. at a time 一次,每次
    54. at all costs 不惜一切代价
    55. at all events 不管怎样,无论如何
    56. at all times 随时,总是
    57. at all 丝毫(不),一点也不
    58. at any rate 无论如何,至少
    59. at best 充其量,至多
    60. at first sight 乍一看,初看起来
    61. at first 最初,起先
    62. at hand 在手边,在附近
    63. at heart 内心里,本质上
    64. at home 在家,在国内
    65. at intervals 不时,每隔...
    66. at large 大多数,未被捕获的
    67. at last 终于
    68. at least 至少
    69. at length 最终,终于
    70. at most 至多,不超过
    71. at no time 从不,决不
    72. at one time 曾经,一度;同时
    73. at present 目前,现在
    74. at someone's disposal 任...处理
    75. at the cost of 以...为代价
    76. at the mercy of 任凭...摆布
    77. at the moment 此刻,目前
    78. at this rate 照此速度
    79. at times 有时,间或
    80. aware of意识到
    81. back and forth 来回地,反复地
    82. back of 在...后面
    83. back up后备,支援
    84. bare of几乎没有,缺乏
    85. be able to do能够
    86. be around差不多
    87. be available to sb.可用,可供
    88. be bound to一定
    89. be capable of doing能够
    90. be concerned with 关心…,涉足…
    91. be dying to渴望
    92. be fed up with受够了be tired of
    93. be in hospital 住院
    94. be in season 上市的/in peak season旺季
    95. be in the mood to do sth. 想做
    96. be pressed for time时间不够
    97. be tied up with忙于
    98. be under the weather 身体不好
    99. beat around the bush 拐弯没角
    100. beat the crowd 避开人群
    101. before long 不久以后
    102. behind schedule 误点
    103. bent on sth. 下定决心做…
    104. beside point 离题的,不相干的
    105. beyond one's ability超越某人的能力
    106. beyond question 毫无疑问
    107. book on reserve 须留的图书
    108. booked up 订完了
    109. bound for开往
    110. break down抛锚
    111. break though突破
    112. break up with和某人分手be through with / be finished with
    113. bring about 使…发生
    114. bring someone up to date帮某人赶上help someone catch up
    115. by accident 偶然
    116. by air 通过航空途径
    117. by all means 尽一切办法,务必
    118. by and by 不久,迟早
    119. by chance 偶然,碰巧
    120. by far 最,...得多
    121. by hand 用手,用体力
    122. by itself 自动地,独自地
    123. by means of 用,依靠
    124. by mistake 错误地,无意地
    125. by no means 决不,并没有
    126. by oneself 单独地,独自地
    127. by reason of 由于
    128. by the way 顺便说说
    129. by virtue of 借助,由于
    130. by way of 经由,通过...方法
    131. call off取消
    132. call on号召,邀请,点某人的名,拜访
    133. capable of能够
    134. careful of/about/with小心,注意
    135. certain of /about确信,肯定
    136. chair a meeting 主持会议
    137. charge sb. with sth.控告
    138. clear of没有,不接触
    139. clever at善于
    140. close to接近,亲近
    141. come in contact with 与…取得联系
    142. come out of sth. alive大难不死
    143. come up (with)提出,拿出
    144. comparable to/with比作/比较
    145. conscious of察觉到,意识到
    146. consequent on随之而来
    147. considerate towards体谅,体贴
    148. contemporary with与...同时代
    149. content with满足于
    150. contrary to违反
    151. cost someone an arm and a leg代价很大
    152. count down倒计时
    153. count one's chickens before they are hatched过于乐观
    154. count on依靠
    155. count on依靠
    156. count the day期待
    157. count the day期待
    158. counter to与...相反
    159. crazy about热衷,着迷
    160. critical of挑剔,批评
    161. cry in one's beer借酒消愁
    162. cry on one's shoulder依靠
    163. curious about好奇,想知道
    164. cut down on 减少
    165. cut down削减
    166. cut in插入
    167. cut off切断
    168. cut out切除
    169. cut someone short打断
    170. cut through抄近路
    171. cut up切碎
    172. die out 灭绝
    173. distinct from种类(风格)不同
    174. do the laundry洗衣服
    175. doubtful of /about怀疑
    176. drop by / in 顺路拜访
    177. due to 由于,因为
    178. each other 互相
    179. easier said than done说起来容易做起来难
    180. east of在...东面
    181. equal to相等,胜任
    182. equivalent to等于,相当于
    183. essential to/for必不可少
    184. even if/though 即使,虽然
    185. ever so 非常,极其
    186. every now and then 时而,偶尔
    187. every other 每隔一个的
    188. except for 除了...外
    189. expert at/in/on善于
    190. face to face 面对面地
    191. faculty members 教职员工
    192. faithful to忠实于
    193. fall flat 平躺在地上
    194. familiar to sb为...所熟悉
    195. familiar with sth熟悉,通晓
    196. far from 远非,远离
    197. fatal to致命的
    198. favorable to支持,赞成
    199. fearful of惧怕
    200. feel at home熟悉
    201. feel blue心情不好
    202. feel free to随便
    203. figure out sth. 解决
    204. fit for适于
    205. flat tire轮胎没气
    206. flat tire轮胎没气
    207. fond of喜欢
    208. for ever 永远
    209. for good 永久地
    210. for the better 好转
    211. for the moment 暂时,目前
    212. for the present 暂时,目前
    213. for the sake of 为了,为了...的利益
    214. for the time being 暂时,眼下
    215. foreign to非...所原有
    216. free of /from未受...;免费
    217. free with康慨,大方
    218. from time to time 有时,不时
    219. full up客满
    220. get a bargain 买到便宜货
    221. get nowhere with 毫无进展
    222. get over恢复
    223. get used to习惯于
    224. give off发出
    225. give someone a big hand为某人鼓掌
    226. give someone a hand帮忙
    227. go about sth. 开始做…
    228. go after追求
    229. go ahead同意做某事
    230. go by遵守
    231. go down下降,往下传
    232. go for竭尽全力做
    233. go into进入,开始从事
    234. go off出发
    235. go out熄灭,外出
    236. go over复习
    237. go over复习,从头到尾检查一遍
    238. go round/around足够分配
    239. go sightseeing 去观光
    240. go steady with和某人确定关系
    241. go through从头到尾
    242. go without单独
    243. guilty of有...罪的
    244. had better最好
    245. hand in hand 手拉手 ,密切关联
    246. hang up 挂断
    247. have one's hands full
    248. have the final say 有决定权
    249. head on 迎面地,正面的
    250. heart and soul 全心全意地
    251. hold out for sth. 坚持要求
    252. hold up坚持
    253. hold water站得住脚
    254. how about ...怎么样
    255. how come怎么会
    256. hungry for渴望
    257. ignorant of不知道
    258. impatient at sth.不耐烦
    259. impatient for急切,渴望
    260. impatient of无法容忍
    261. in (the)light of 鉴于,由于
    262. in a hurry 匆忙,急于
    263. in a moment 立刻,一会儿
    264. in a sense 从某种意义上说
    265. in a way 在某种程度上
    266. in a word 简言之,总之
    267. in accordance with 与...一致,按照
    268. in addition to 除...之外(还)
    269. in addition 另外,加之
    270. in advance 预先,事先
    271. in all 总共,合计
    272. in any case 无论如何
    273. in any event 无论如何
    274. in brief 简单地说
    275. in case of 假如,防备
    276. in charge of 负责,总管
    277. in common 共用的,共有的
    278. in consequence(of) 因此;由于
    279. in debt 欠债,欠情
    280. in detail 详细地
    281. in difficulty 处境困难
    282. in effect 实际上,事实上
    283. in favor of 支持,赞成
    284. in front of 面对,在...前
    285. in general 一般来说,大体上
    286. in half 成两半
    287. in hand 在进行中,待办理
    288. in honor of 为庆祝,为纪念
    289. in itself 本质上,就其本身而言
    290. in line with 与...一致
    291. in memory of 纪念
    292. in no case 决不
    293. in no time 立即,马上
    294. in no way 决不
    295. in order 按顺序,按次序
    296. in other words 换句话说
    297. in part 部分地
    298. in particular 特别,尤其
    299. in person 亲自,本人
    300. in place of 代替,取代,交换
    301. in place 在合适的位置
    302. in practice 在实践中,实际上
    303. in proportion to 与...成比例
    304. in public 公开地,当众
    305. in quantity 大量
    306. in question 正在谈论的
    307. in regard to 关于,至于
    308. in relation to 关于,涉及
    309. in return for 作为对...报答
    310. in return 作为报答/回报/交换
    311. in short 简言之,总之
    312. in sight 被见到;在望
    313. in spite of 尽管
    314. in step with 与...一致/协调
    315. in tears 流着泪,在哭着
    316. in terms of
    317. in the company / wake of随着
    318. in the course of 在...期间/过程中
    319. in the distance 在远处
    320. in the end 最后,终于
    321. in the event of 如果...发生,万一
    322. in the face of 即使;在...面前
    323. in the first place 首先
    324. in the future 在未来
    325. in the heat of the day 一天中最热的时候
    326. in the least 丝毫,一点
    327. in the long run 长期
    328. in the way 挡道
    329. in the world 究竟,到底
    330. in time 及时
    331. in touch 联系,接触
    332. in turn 依次,轮流;转而
    333. in vain 徒劳,白费力
    334. indifferent to无兴趣,不关心
    335. indignant with sb.愤慨
    336. inferior to级别低于,不如
    337. innocent of无...罪,无辜
    338. instead of 代替,而不是
    339. intent on专心于
    340. invisible to不可见的
    341. jealous of嫉妒
    342. just now 眼下;刚才
    343. keep one's eyes on关注
    344. keep on爱好,很喜欢
    345. keep track of 留心
    346. kind of / sort of有点somewhat
    347. lay off 下岗
    348. leave alone别说
    349. let the cat out of the bag泄露秘密
    350. liable for对...有责任
    351. liable to易于
    352. little by little 逐渐地
    353. look for / hunt for 找工作
    354. lost the point弄错
    355. lots of 许多
    356. loyal to忠于
    357. mad about/on狂热迷恋
    358. mad at/with sb.生气,愤怒
    359. mad with因...发狂
    360. make (both) ends meet收支平衡
    361. make a living谋生
    362. make it成功
    363. make the best / most of充分利用
    364. many a 许多
    365. mark the papers 批改考卷
    366. mayor / minor in
    367. meet one's needs满足要求
    368. might as well不妨
    369. mistake a for b 认错
    370. more or less 或多或少,有点
    371. my treat我请客
    372. narrow escape九死一生
    373. necessary to /for必要的
    374. next door 隔壁的,在隔壁
    375. next to下一个,其次
    376. no doubt 无疑地
    377. no less than 不少于...;不亚于
    378. no longer 不再
    379. no more than 至多,同...一样不
    380. no more 不再
    381. none other than 不是别的,正是
    382. nothing but 只有,只不过
    383. now and then 时而,偶尔
    384. off and on 断断续续,间歇地
    385. off duty 下班
    386. on (the) one hand 一方面
    387. on a large/small scale 大/小规模地
    388. on account of 由于
    389. on behalf of 代表
    390. on board 在船(车/飞机)上
    391. on business 因公
    392. on condition that 如果
    393. on duty 上班,值班
    394. on earth 究竟,到底
    395. on fire 起火着火
    396. on foot 步行
    397. on guard 站岗,值班
    398. on hand 在场,在手边
    399. on loan to借给
    400. on occasion(s) 有时,间或
    401. on one's guard 警惕,提防
    402. on one's own 独立,独自
    403. on purpose 故意地
    404. on sale 出售,廉价出售
    405. on schedule 按时间表,准时
    406. on second thoughts 经重新考虑
    407. on the contrary 正相反
    408. on the grounds of 根据,以...为由
    409. on the other hand 另一方面
    410. on the point of 即将...的时刻
    411. on the road 在旅途中
    412. on the side 作为兼职/副 业
    413. on the spot 在场;马上
    414. on the whole 总的来说,大体上
    415. on time 准时
    416. on(an/the) average 平均,通常
    417. once (and) for all 一劳永逸地
    418. once again 再一次
    419. once in a while 偶尔
    420. once more 再一次
    421. once upon a time 从前
    422. one another 相互
    423. one's cup of tea喜欢的人/物
    424. open to不限制,开放的
    425. opposite to在对面
    426. or else 否则,要不然
    427. or so 大约,左右
    428. other than 非;除了
    429. out of breath 喘不过气来
    430. out of control 失去控制
    431. out of date 过时的
    432. out of doors 在户外
    433. out of order 出故障的
    434. out of place 不适当的
    435. out of practice 久不练习,荒疏
    436. out of sight 看不见,在视野外
    437. out of the question 毫无可能的
    438. out of touch 不联系,不接触
    439. out of 从...中;由于;缺乏
    440. over and over (again) 一再地,再三地
    441. parallel to与...平等,类似
    442. particular about挑剔,讲究
    443. patient with有耐心
    444. peculiar to独特的,独有的
    445. pick up捡
    446. play by ear见机行事
    447. popular with受...喜爱,爱戴
    448. prior to 在...之前
    449. pull one's leg拿某人开玩笑put someone on
    450. put someone up给某人提供住宿
    451. put up with忍受
    452. quite a few 相当多,不少
    453. rain cats and dogs瓢泼大雨
    454. rather than 不是...(而是)
    455. reach agreement 达成协议
    456. reach an agreement达成一致
    457. regardless of 不顾,不惜
    458. relative to与...有关
    459. remove from 从…除去
    460. representative of代表...的
    461. resign one's post 辞职
    462. responsible for负责,是...原因
    463. result from 由于
    464. rich in富于
    465. right away 立即,马上
    466. ring sb. up 打电话给…
    467. rule out 排除…的可能性
    468. run out of用完
    469. rush hours上下班高峰
    470. see: see to it that - make sure that确保
    471. sensible of觉查到
    472. sensitive to对...敏感
    473. set another date改期 make on saturday / lock it
    474. set one's mind on doing 决定be determined to / have one's mind set on / bent on
    475. short of缺少
    476. show off卖弄
    477. sick of厌恶,厌倦
    478. side by side 肩并肩,一起
    479. similar to相似
    480. skilled at /in善于
    481. slip one's mind 忘记
    482. so far 迄今为止
    483. somewhere around 大约
    484. sooner or later 迟早,早晚
    485. sore throat / foot
    嗓子哑/腿酸
    486. stay up late 熬夜
    487. step by step 逐步地
    488. subject to受制于,易于
    489. such as 例如,诸如
    490. sufficient for足够的
    491. suitable for/to适合于
    492. superior to优于,级别高于
    493. sure of /about对...有信心,确信
    494. suspicious of怀疑
    495. take a leave请假
    496. take a seat / be seated
    497. take one's place 取代
    498. take one's time慢慢来
    499. take sth. seriously 认真对待
    500. take up占据
    501. thanks to 由于,多亏
    502. that is (to say) 就是说,即
    503. the reverse is also true 反之亦然
    504. tired of对...不在感兴趣
    505. to the point 切中要害,切题
    506. turn over 倾覆
    507. typical of是典型的,特有的
    508. uncertain of /about不确知
    509. under control 处于控制之下
    510. under the circumstances 这种情况下
    511. up in the air没有确定
    512. up to date 在进行中
    513. up to 多达;直到;胜任;取决于
    514. vital to对...关系重大
    515. void of没有,缺乏
    516. what about 怎么样
    517. what if 切合目前情况的
    518. what's up / new?发生了什么事?
    519. with regard to 关于,至于
    520. with respect to 如果...将怎么样
    521. with the exception of 除...之外
    522. without any trace没有踪迹
    523. without fail 一向如此
    524. without question 毫无疑问
    525. wolf down狼吞虎咽
    526. word for word 逐字的
  • 签到天数: 758 天
    发表于 2014-11-25 08:52:55 | 显示全部楼层
    GMT+8, 2025-4-19 05:41 , Processed in 0.069644 second(s), 23 queries .
