TA的每日心情 | 开心 4 天前 |
签到天数: 265 天 [LV.8]以坛为家I
发表于 2014-10-23 09:31:29
显示全部楼层
Petrel软件里面的完井设计( Well Completion Design)可以添加压裂事件用于模拟全区的压裂,生成的数据体可以直接调用ECLIPSE运算。
以下是从帮助中摘录的说明:
Hydraulic fracture
To create a hydraulic fracture, in addition to the date and the event name, you need to specify the following:
1.The center of the fracture in measured depth (MD).
2.The top of the fracture in true vertical depth sub sea level (TvdSS).
3.The bottom of the fracture in TvdSS.
4.The length of the fracture.
5.The orientation of the fracture.
6.The permeability of the fracture.
7.The width of the fracture.
以下是需要准备的用于导入的事件文件,和ECLIPSE做Schedule用的event文件格式一致。
-- This is a comment line
UNITS METRIC
WELLNAME WELL-1
--DATE HYDR-FRAC Center(MD) Top(TvdSS) Bottom(TvdSS) Length Orientation Permeability Width
01/01/2000 hydr-frac 1515 1505 1525 100 0 10000 0.005
