查看: 1511|回复: 2
[经验交流] 裂缝井产能评价SPE
  • 签到天数: 4 天
    发表于 2014-8-18 16:44:30 | 显示全部楼层 |阅读模式
    裂缝井产能评价SPE, 必须要读的文献,总有一篇适合你的
    A Complete Set of Laplace Transforms for Finite-Conductivity Vertical Fractures .pdf
    770.08 KB, 下载次数: 1
    售价: 2 阳光币  [记录]
    A Discrete Fracture Network Model for Hydraulically Induced Fractures - Theory, .pdf
    2.56 MB, 下载次数: 2
    售价: 2 阳光币  [记录]
    A New Approximate Analytic Solution for Finite-Conductivity Vertical Fractures.pdf
    829.19 KB, 下载次数: 1
    售价: 2 阳光币  [记录]
    A New Model for Determining the Radius of Mud Loss During Drilling Operation in .pdf
    1.01 MB, 下载次数: 1
    售价: 2 阳光币  [记录]
    1.01 MB, 下载次数: 1
    售价: 2 阳光币  [记录]
    A Simple and Accurate Model for Well Productivity for Hydraulically Fractured Wells.pdf
    545.01 KB, 下载次数: 1
    售价: 2 阳光币  [记录]
    A Simple Method for Correcting Spot Pressure Readings.pdf
    225.93 KB, 下载次数: 1
    售价: 2 阳光币  [记录]
    Agrwal Analyzing Well Production Data Using Combined Type Curve and Decline Curv.pdf
    1.06 MB, 下载次数: 1
    售价: 2 阳光币  [记录]
    1.06 MB, 下载次数: 2
    售价: 2 阳光币  [记录]
    Bennett Influence of Fracture Heterogeneity and Wing Length on the Response of V.pdf
    817.95 KB, 下载次数: 3
    售价: 2 阳光币  [记录]
    Characterization of Hydraulically-Induced Shale Fracture Network Using An Analyt.pdf
    489.38 KB, 下载次数: 1
    售价: 2 阳光币  [记录]
    489.38 KB, 下载次数: 1
    售价: 2 阳光币  [记录]
    Crawford Effect of Unsymmetrical Vertical Fractures on Production Capacity.pdf
    344.63 KB, 下载次数: 1
    售价: 2 阳光币  [记录]
    Development of the Brittle Shale Fracture Network Model.pdf
    1.11 MB, 下载次数: 1
    售价: 2 阳光币  [记录]
    Effects of Normal and Shear Stresses on Permeability of Radial Fractures Around .pdf
    1.18 MB, 下载次数: 1
    售价: 2 阳光币  [记录]
    Hydraulic Fracturing Optimization for Unconventional Reservoirs - The Critical R.pdf
    1.09 MB, 下载次数: 2
    售价: 2 阳光币  [记录]
    Mcguire The Effect of Vertical Fractures on Well Productivity MMcguire.pdf
    178.51 KB, 下载次数: 1
    售价: 2 阳光币  [记录]
    Modeling Multiple Hydraulic Fractures Interacting with Natural Fractures Using t.pdf
    3.1 MB, 下载次数: 1
    售价: 2 阳光币  [记录]
    Modeling simultaneous growth of multiple hydraulic fractures and their interacti.pdf
    172.55 KB, 下载次数: 1
    售价: 2 阳光币  [记录]
    Modeling the Influence of Pressure Depletion in Fracture Propagation and Quantif.pdf
    930.39 KB, 下载次数: 0
    售价: 2 阳光币  [记录]
    Multiple Fractures Transient Response.pdf
    459.67 KB, 下载次数: 2
    售价: 2 阳光币  [记录]
    Multiple Radial Fracturing From A Wellbore - Experimental And Theoretical Results.pdf
    475.61 KB, 下载次数: 4
    售价: 2 阳光币  [记录]
    Multiple Radial Fracturing From A Wellbore Conceptual Model And Experiments.pdf
    686.03 KB, 下载次数: 1
    售价: 2 阳光币  [记录]
    Multiple-Fractures Propagation, Orientation and Complexities in Drilling Waste I.pdf
    627.72 KB, 下载次数: 2
    售价: 2 阳光币  [记录]
    Multi-Scale Fracture Creation and Network Generation During Hydraulic Fracturing.pdf
    2.46 MB, 下载次数: 0
    售价: 2 阳光币  [记录]
    Narasimhan A Purely Numerical Approach For Analyzing Fluid Flow To A Well Interc.pdf
    967.57 KB, 下载次数: 2
    售价: 2 阳光币  [记录]
    New Solutions 1 part.pdf
    831.75 KB, 下载次数: 1
    售价: 2 阳光币  [记录]
    NewsolutionsforWell-estAnalysisProblems.pdf
    735.12 KB, 下载次数: 3
    售价: 2 阳光币  [记录]
    Numerical Analysis Of Multiple Radial Fracturing.pdf
    498.49 KB, 下载次数: 2
    售价: 2 阳光币  [记录]
    Parts finite conductiviy effective radius.pdf
    826.75 KB, 下载次数: 2
    售价: 2 阳光币  [记录]
    Poe Production Performance Evaluation of Hydraulically Fractured Wells Poe.pdf
    147.54 KB, 下载次数: 1
    售价: 2 阳光币  [记录]
    Post-Treatment Assessment of Induced Fracture Networks.pdf
    570.4 KB, 下载次数: 2
    售价: 2 阳光币  [记录]
    racture Complexity Impacts on Pressure Transient Responses From Horizontal Wells.pdf
    1.37 MB, 下载次数: 1
    售价: 2 阳光币  [记录]
    Radial Cracking of a Borehole By Pressure And Thermal Shock.pdf
    98.7 KB, 下载次数: 2
    售价: 2 阳光币  [记录]
    Raymond Productivity of Wells in Vertically Fractured, Damaged Formations Roymond.pdf
    1.15 MB, 下载次数: 2
    售价: 2 阳光币  [记录]
    Semi-Analytical Production Simulation of Complex Hydraulic Fracture Network.pdf
    6.65 MB, 下载次数: 1
    售价: 2 阳光币  [记录]
    Simulation of Fluid Flow in Coal Using a Discrete Fracture Network Model.pdf
    602.28 KB, 下载次数: 1
    售价: 2 阳光币  [记录]
    The application of a three-dimensional fracture network model to a hot-dry-rock .pdf
    703.73 KB, 下载次数: 1
    售价: 2 阳光币  [记录]
    The Potential Effect of Network Complexity on Recovery of Injected Fluid Followi.pdf
    793.27 KB, 下载次数: 1
    售价: 2 阳光币  [记录]
    一种压裂水平井产能计算方法_丁一萍.pdf
    227.34 KB, 下载次数: 2
    售价: 2 阳光币  [记录]
  • 签到天数: 85 天
    发表于 2014-8-18 21:04:19 | 显示全部楼层
    不错!
  • 签到天数: 2595 天
    发表于 2017-2-19 15:45:36 | 显示全部楼层
    GMT+8, 2025-5-15 08:09 , Processed in 0.055780 second(s), 23 queries .
