查看: 1031|回复: 0
[资料贴] Colloid Science Principles, methods and applications Second Edition
  • 签到天数: 3 天
    发表于 2014-5-30 19:54:52 | 显示全部楼层 |阅读模式
    Colloid Science Principles, methods and applications Second Edition基本信息
    • 出版社: Wiley-Blackwell; 2 (2010年5月10日)
    • 精装: 394页
    • 语种: 英语
    图书目录Preface.
    Introduction.
    Acknowledgements.
    List of Contributors.
    1 An Introduction to Colloids (Roy Hughes).
    1.1 Introduction.
    1.2 Basic Definitions.
    1.3 Stability.
    1.4 Colloid Frontiers.
    2 Charge in Colloidal Systems (David Fermin and Jason Riley).
    2.1 Introduction.
    2.2 The Origin of Surface Charge.
    2.3 The Electrochemical Double Layer.
    2.4 Electrokinetic Properties.
    3 Stability of Charge-stabilised Colloids (John Eastman).
    3.1 Introduction.
    3.2 The Colloidal Pair Potential.
    3.3 Criteria for Stability.
    3.4 Kinetics of Coagulation.
    3.5 Conclusions.
    4 Surfactant Aggregation and Adsorption at Interfaces (Julian Eastoe).
    4.1 Introduction.
    4.2 Characteristic Features of Surfactants.
    4.3 Classification and Applications of Surfactants.
    4.4 Adsorption of Surfactants at Interfaces.
    4.5 Surfactant Solubility.
    4.6 Micellisation.
    4.7 Liquid Crystalline Mesophases.
    4.8 Advanced Surfactants.
    5 Microemulsions (Julian Eastoe).
    5.1 Introduction.
    5.2 Microemulsions: Definition and History.
    5.3 Theory of Formation and Stability.
    5.4 Physicochemical Properties.
    5.5 Developments and Applications.
    6 Emulsions (Brian Vincent).
    6.1 Introduction.
    6.2 Preparation.
    6.3 Stability.
    7 Polymers and Polymer Solutions (Terence Cosgrove).
    7.1 Introduction.
    7.2 Polymerisation.
    7.3 Copolymers.
    7.4 Polymer Physical Properties.
    7.5 Polymer Uses.
    7.6 Theoretical Models of Polymer Structure.
    7.7 Measuring Polymer Molecular Weight.
    7.8 Flory-Huggins Theory.
    8 Polymers at Interfaces (Terence Cosgrove).
    8.1 Introduction.
    8.2 Adsorption of Polymers.
    8.3 Models and Simulations for Terminally Attached Chains.
    8.4 Experimental Aspects.
    8.5 Copolymers.
    8.6 Polymer Brushes.
    8.7 Conclusions.
    9 Effect of Polymers on Colloid Stability (Jeroen van Duijneveldt).
    9.1 Introduction.
    9.2 Particle Interaction Potential.
    9.3 Steric Stabilisation.
    9.4 Depletion Interactions.
    9.5 Bridging Interactions.
    9.6 Conclusion.
    10 Wetting of Surfaces (Paul Reynolds).
    10.1 Introduction.
    10.2 Surfaces and Definitions.
    10.3 Surface Tension.
    10.4 Surface Energy.
    10.5 Contact Angles.
    10.6 Wetting.
    10.7 Liquid Spreading and Spreading Coefficients.
    10.8 Cohesion and Adhesion.
    10.9 Two Liquids on a Surface.
    10.10 Detergency.
    10.11 Spreading of a Liquid on a Liquid.
    10.12 Characterisation of a Solid Surface.
    10.13 Polar and Dispersive Components.
    10.14 Polar Materials.
    10.15 Wettability Envelopes.
    10.16 Measurement Methods.
    10.17 Conclusions.
    11 Aerosols (Nana-Owusua A. Kwamena and Jonathan P. Reid).
    11.1 Introduction.
    11.2 Generating and Sampling Aerosols.
    11.3 Determining the Particle Concentration and Size.
    11.4 Determining Particle Composition.
    11.5 The Equilibrium State of Aerosols.
    11.6 The Kinetics of Aerosol Transformation.
    11.7 Concluding Remarks.
    12 Practical Rheology (Roy Hughes).
    12.1 Introduction.
    12.2 Making Measurements.
    12.3 Rheometry and Viscoelasticity.
    12.4 Examples of Soft Materials.
    12.5 Summary.
    13 Scattering and Reflection Techniques (Robert Richardson).
    13.1 Introduction.
    13.2 The Principle of a Scattering Experiment.
    13.3 Radiation for Scattering Experiments.
    13.4 Light Scattering.
    13.5 Dynamic Light Scattering.
    13.6 Small Angle Scattering.
    13.7 Sources of Radiation.
    13.8 Small Angle Scattering Apparatus.
    13.9 Scattering and Absorption by Atoms.
    13.10 Scattering Length Density.
    13.11 Small Angle Scattering from a Dispersion.
    13.12 Form Factor for Spherical Particles.
    13.13 Determining Particle Size from SANS and SAXS.
    13.14 Guinier Plots to Determine Radius of Gyration.
    13.15 Determination of Particle Shape.
    13.16 Polydispersity.
    13.17 Determination of Particle Size Distribution.
    13.18 Alignment of Anisotropic Particles.
    13.19 Concentrated Dispersions.
    13.20 Contrast Variation Using SANS.
    13.21 High Q Limit: Porod Law.
    13.22 Introduction to X-Ray and Neutron Reflection.
    13.23 Reflection Experiment.
    13.24 A Simple Example of a Reflection Measurement.
    13.25 Conclusion.
    14 Optical Manipulation (Paul Bartlett).
    14.1 Introduction.
    14.2 Manipulating Matter with Light.
    14.3 Force Generation in Optical Tweezers.
    14.4 Nanofabrication.
    14.5 Single Particle Dynamics.
    14.6 Conclusions.
    15 Electron Microscopy (Sean Davis).
    15.1 General Features of (Electron) Optical Imaging Systems.
    15.2 Conventional TEM.
    15.3 Conventional SEM.
    15.4 Summary.
    16 Surface Forces (Wuge Briscoe).
    16.1 Introduction.
    16.2 Forces and Energy; Size and Shape.
    16.3 Surface Force Measurement Techniques.
    16.4 Different Types of Surface Forces.
    16.5 Recent Examples of Surface Force Measurement.
    16.6 Future Challenges.
    References.
    Index.
    图书描述出版日期: 2010年5月10日
    Colloidal systems are important across a range of industries, such as the food, pharmaceutical, agrochemical, cosmetics, polymer, paint and oil industries, and form the basis of a wide range of products (eg cosmetics & toiletries, processed foodstuffs and photographic film). A detailed understanding of their formation, control and application is required in those industries, yet many new graduate or postgraduate chemists or chemical engineers have little or no direct experience of colloids.Based on lectures given at the highly successful Bristol Colloid Centre Spring School, Colloid Science: Principles, Methods and Applications provides a thorough introduction to colloid science for industrial chemists, technologists and engineers. Lectures are collated and presented in a coherent and logical text on practical colloid science.
    Colloid Science Principles, Methods and Applications.pdf
    6.37 MB, 下载次数: 0
    售价: 5 阳光币  [记录]  [购买]
    表面活性剂专用书籍
    GMT+8, 2026-2-20 13:59 , Processed in 0.072419 second(s), 27 queries .
