查看: 985|回复: 2
[求助] 净总厚度比
  • 签到天数: 1082 天
    发表于 2014-3-7 09:51:28 | 显示全部楼层 |阅读模式
    哪位大神能告诉我净总厚度比是什么意思吗
    发表于 2014-3-7 12:45:24 | 显示全部楼层
    Net to Gross (NTG, N/G)?
    (From Wikipedia)
    Hydrocarbon in place - amount of hydrocarbon likely to be contained in the prospect. This is calculated using the volumetric equation - GRV x N/G x Porosity x Sh x FVF
       GRV - Gross rock volume - amount of rock in the trap above the hydrocarbon water contact
       N/G - net/gross ratio - proportion of the GRV formed by the reservoir rock ( range is 0 to 1)
       Porosity - percentage of the net reservoir rock occupied by pores (typically 5-35%)
       Sh - hydrocarbon saturation - some of the pore space is filled with water - this must be discounted
       FVF - formation volume factor - oil shrinks and gas expands when brought to the surface. The FVF converts volumes at reservoir conditions (high pressure and high temperature) to storage and sale conditions
    参与人数 1阳光币 +5 收起 理由
    swpuxiaofan + 5 解疑答惑,帮助他人
  • 签到天数: 1082 天
     楼主| 发表于 2014-3-9 21:10:46 | 显示全部楼层
    非常感谢,只是英文的看起来有些吃力啊
    GMT+8, 2025-5-10 04:29 , Processed in 0.046270 second(s), 20 queries .
