查看: 1110|回复: 3
Schlumberger Introduces New Fracturing Technique
  • 签到天数: 57 天
    发表于 2014-2-20 14:21:42 | 显示全部楼层 |阅读模式
    BroadBand Sequence significantly increases productivity in unconventional reservoir completions
    HOUSTON, February 19, 2014—Schlumberger announced today the introduction of the BroadBand Sequence* fracturing technique, which enables sequential stimulation of perforation clusters in wells drilled in unconventional reservoirs. This new technique sequentially isolates fractures at the wellbore to ensure every cluster in each zone is fractured resulting in greater production and completion efficiency compared to conventional methods.
    Developed using a composite fluid comprising a proprietary blend of degradable fibers and multimodal particles, the BroadBand Sequence technique is suited for use in new wells and in recompletions. This technique is particularly suitable for re-fracturing operations, given its ability to promote temporary cluster isolation without the aid of mechanical devices such as bridge plugs.
    “Optimizing the stimulation of wellbore perforation clusters in unconventional reservoirs is a significant challenge for our industry,” said Amerino Gatti, president, Well Services, Schlumberger. “The BroadBand Sequence technique addresses this challenge and increases our customers’ well production by enhancing stimulation contact in every zone in the reservoir.”
    This fracturing technique has delivered robust and consistent performance in more than 500 operations conducted to date in several unconventional plays including the Eagle Ford, Haynesville, Woodford, Spraberry and Bakken shales.
    The BroadBand Sequence fracturing technique has enabled customers in South Texas to increase production from new completions in unconventional reservoirs by more than 20%. It has also reduced well completion time by up to 46% in plug-and-perf operations by stimulating longer intervals compared with conventional methods. In addition, this technology was applied to a well in South Texas for a refracturing operation, which resulted in double the production with a fourfold increase in flowing pressure.
    BroadBand Sequence is the first release of a family of BroadBand completion technologies aimed at maximizing well productivity in unconventional reservoirs.
    For more information about the BroadBand Sequence fracturing technique, visitwww.slb.com/BroadBand.
  • 签到天数: 8 天
    发表于 2014-2-21 10:07:42 | 显示全部楼层
    高速通道压裂,今年要开展此技术施工
  • 签到天数: 599 天
    发表于 2014-6-29 15:22:15 来自阳光石油论坛手机版 | 显示全部楼层
    学习一下
  • 签到天数: 454 天
    发表于 2014-7-19 18:22:55 来自阳光石油论坛手机版 | 显示全部楼层
    学习了
    GMT+8, 2025-4-25 00:09 , Processed in 0.046472 second(s), 19 queries .
