查看: 6899|回复: 15
[Petrel] petrel 安装问题
  • 签到天数: 26 天
    发表于 2009-5-15 11:03:24 | 显示全部楼层 |阅读模式
    petrel安装
    许可出现下列
    (10:58:26)  The version of lmgrd.exe is 11, 3, 0, 0 The modified date is 2006-11-30 10:22:16
    (10:58:27)  The version of slbsls.exe is 1, 2, 0, 0 The modified date is 2007-7-19 6:11:42
    (10:58:27)  The version of SLBLicensing.exe is 3.9.0.2 The modified date is 2007-4-25 15:21:02
    (10:58:27)  The LM_LICENSE_FILE User Environment variable is set to = C:\ProgramFiles\Schlumberger\SchlumbergerLicensing\flex113\license2007.lic
    (10:58:27)  The LM_LICENSE_FILE System Environment variable is set to = C:\C:\ProgramFiles\Schlumberger\SchlumbergerLicensing\flex113\license2007.lic;C:\Landmark\LAM\license.dat;2013@cn-901eac788f31;@2013@cn-901eac788f31;8888@localhost;2387@localhost;
    (10:58:28)  The following file C:\ProgramFiles\Schlumberger\SchlumbergerLicensing\flex113\license2007.lic does not exist
    (10:58:28)  The following file C:\C:\ProgramFiles\Schlumberger\SchlumbergerLicensing\flex113\license2007.lic does not exist
    (10:58:28)  The following file C:\Landmark\LAM\license.dat does not exist
    (10:58:28)  Schlumberger License Server Is running on the machine
    (10:58:28)  The registry contains the following license files = c:\program files\schlumberger\schlumberger licensing\flex113\license2007.lic
    (10:58:28)  c:\program files\schlumberger\schlumberger licensing\flex113\license2007.lic contains the following:
    各位分析下,
  • 签到天数: 149 天
    发表于 2009-5-15 11:19:58 | 显示全部楼层
    这还隐藏???没心情分析了·~~~~~~~~~
    发表于 2009-5-15 14:17:52 | 显示全部楼层
    前几天下的破解直接被我杀毒软件当毒杀了~还是没安成~~哎~
    希望LZ早日也能解决问题吧~~
  • 签到天数: 26 天
     楼主| 发表于 2009-5-15 14:23:43 | 显示全部楼层
    为了避免因引起不必要的麻烦,对是crack的部分隐藏下!
    发表于 2009-5-15 14:36:05 | 显示全部楼层
    不是很好分析,只有自己慢慢摸索才可以,只要破解没问题的话,那就是安装过程了
    好像是破解有问题~~~
    发表于 2009-5-15 21:57:31 | 显示全部楼层
    破解有问题
  • 签到天数: 117 天
    发表于 2009-5-16 01:01:11 | 显示全部楼层
    许可设置不对
    环境变量有问题
    网卡地址好象也要改
    发表于 2009-5-19 12:08:20 | 显示全部楼层
    楼主辛苦啦
  • 签到天数: 197 天
    发表于 2012-10-17 23:46:11 | 显示全部楼层
    什么情况?
  • 签到天数: 452 天
    发表于 2012-10-18 10:34:12 | 显示全部楼层
    kankan>>>>>
    GMT+8, 2026-4-24 15:04 , Processed in 0.242351 second(s), 22 queries .
