查看: 3914|回复: 2
[其他软件] SEGY Viewer
  • 签到天数: 119 天
    发表于 2014-2-12 23:30:10 | 显示全部楼层 |阅读模式
    SEGY Viewer is a trace and trace header SEGY file viewer from geoPLUS Corporation.
    To Start, Browse to the folder containing the SEGY files and select a file to open.  All
    files with the same extension will be shown in the Segy Files listbox.  Select file from
    listbox, note that samples, sample rate, and data format are shown below while number of traces,
    and format code are shown on the status bar.  The EBCDIC header is shown on the left side
    of the tabbed sheet.
    To see the trace header values, click on Scan Headers to read all trace headers and show
    the min and max value for each 2 byte and 4 byte header location.
    To view the traces select the Data tab.  The traces are shown in variable area mode and
    left to right.  They are labeled by default as sequential trace numbers, alternate labeling
    can be done by selecting a header word to display as a label.  To select a header word
    click in the select column of the desired row and from the popup menu select "Label".  Select the
    Data tab to view the changes.  The Zoom Out button allows a less detailed view of the traces.
    To override the default data format select the required Data Type and Data Word length
    for the data samples from the drop down combo boxes.
    SEGY Viewer.rar
    1.38 MB, 下载次数: 44
    售价: 3 阳光币  [记录]
    SEGY Viewer
    参与人数 1阳光币 +10 收起 理由
    Eason-CUG + 10 新手启动资金!
  • 签到天数: 77 天
    发表于 2014-9-16 17:48:09 | 显示全部楼层
  • 签到天数: 28 天
    发表于 2020-8-24 10:33:45 | 显示全部楼层
    谢谢
    GMT+8, 2026-4-21 10:28 , Processed in 0.128447 second(s), 32 queries .
