查看: 56980|回复: 62
Shale Oil Production Performance from a Stimulated Reservoir Volume
  • 签到天数: 37 天
    发表于 2014-2-11 19:33:15 | 显示全部楼层 |阅读模式
    Title:
    Author:
    Chaudhary, Anish Singh
    Abstract:
    The horizontal well with multiple transverse fractures has proven to be an effective strategy for shale gas reservoir exploitation. Some operators are successfully producing shale oil using the same strategy. Due to its higher viscosity and eventual 2-phase flow conditions when the formation pressure drops below the oil bubble point pressure, shale oil is likely to be limited to lower recovery efficiency than shale gas. However, the recently discovered Eagle Ford shale formations is significantly over pressured, and initial formation pressure is well above the bubble point pressure in the oil window. This, coupled with successful hydraulic fracturing methodologies, is leading to commercial wells. This study evaluates the recovery potential for oil produced both above and below the bubble point pressure from very low permeability unconventional shale oil formations.  We explain how the Eagle Ford shale is different from other shales such as the Barnett and others. Although, Eagle Ford shale produces oil, condensate and dry gas in different areas, our study focuses in the oil window of the Eagle Ford shale. We used the logarithmically gridded locally refined gridding scheme to properly model the flow in the hydraulic fracture, the flow from the fracture to the matrix and the flow in the matrix. The steep pressure and saturation changes near the hydraulic fractures are captured using this gridding scheme. We compare the modeled production of shale oil from the very low permeability reservoir to conventional reservoir flow behavior.   We show how production behavior and recovery of oil from the low permeability shale formation is a function of the rock properties, formation fluid properties and the fracturing operations. The sensitivity studies illustrate the important parameters affecting shale oil production performance from the stimulated reservoir volume. The parameters studied in our work includes fracture spacing, fracture half-length, rock compressibility, critical gas saturation (for 2 phase flow below the bubble point of oil), flowing bottom-hole pressure, hydraulic fracture conductivity, and matrix permeability.   The sensitivity studies show that placing fractures closely, increasing the fracture half-length, making higher conductive fractures leads to higher recovery of oil. Also, the thesis stresses the need to carry out the core analysis and other reservoir studies to capture the important rock and fluid parameters like the rock permeability and the critical gas saturation.
    Subject:
    shale oil
    Eagle Ford
  • 签到天数: 113 天
    发表于 2014-2-11 19:52:08 | 显示全部楼层
    这个必须顶下
  • 签到天数: 680 天
    发表于 2014-2-11 20:33:00 | 显示全部楼层
    谢谢分享!
  • 签到天数: 1060 天
    发表于 2014-2-11 20:44:10 | 显示全部楼层
    谢谢分享!!
  • 签到天数: 45 天
    发表于 2014-2-11 21:04:01 | 显示全部楼层
    xiexie分享
    发表于 2014-2-11 21:57:52 | 显示全部楼层
    好东西啊
  • 签到天数: 1882 天
    发表于 2014-2-12 00:34:04 | 显示全部楼层
    资料很好感谢提供
  • 签到天数: 11 天
    发表于 2014-2-12 08:14:14 | 显示全部楼层
    必须要顶!
  • 签到天数: 722 天
    发表于 2014-2-12 08:56:50 | 显示全部楼层
  • 签到天数: 29 天
    发表于 2014-2-12 09:19:16 | 显示全部楼层
    是页岩油吗?
    GMT+8, 2026-6-19 02:29 , Processed in 0.042969 second(s), 23 queries .
