查看: 1973|回复: 10
A Study on Newton Related Nonlinear Methods in Well Test Analysis, Production...
  • 签到天数: 37 天
    发表于 2014-2-10 16:27:46 | 显示全部楼层 |阅读模式
    Author:
    Jawahar Barua
    Year:
    1989
    Degree:
    PhD
    Adviser:
    Horne
    Abstract:
    This is a study on the use of alternative nonlinear methods in automated well test analysis, production and injection schedule optimization and in reservoir simulation.
    In automated well test analysis the advantages and disadvantages of second-order partial derivatives are investigated. Newton's method is shown to be prone to diffculties, however by adjusting the eigenvalues of the Hessian matrix, the performance can be substantially improved.
    In optimizing the cyclic steam injection process, Newton's method is compared with the Quasi-Newton method using a simplified model to simulate the process. The Quasi-Newton method does significantly better than Newton's method in saving function evaluations. Specific operating strategies for the process are identified: the need to eliminate soak, the need for greatly increased steam volumes and temperatures, and the need to optimize a combination of economic objectives.
    The two methods are then compared in reservoir simulation. Tests show that while it is possible to use the Quasi-Newton method to build up inverse Jacobians as the iterations proceed, for dicult problems the method requires the use of matrix solution techniques. The method then becomes directly comparable to Newton's method. Tests show that depending upon the linear scheme used, and the difficulty of the problem, the Quasi-Newton method may prove to be less expensive than Newton's method in certain cases.
    The study also addresses the issue of building scalable parallel reservoir simulators. Residual constraints are used to improve the robustness of the parallel matrix solution scheme. The solution of the constraint matrix is shown to be a critical point in achieving good performance on a parallel machine
  • 签到天数: 833 天
    发表于 2014-2-10 16:30:43 | 显示全部楼层
  • 签到天数: 126 天
    发表于 2014-2-10 16:31:01 | 显示全部楼层
    发表于 2014-2-10 16:36:14 | 显示全部楼层
    thanks a lot!
  • 签到天数: 113 天
    发表于 2014-2-10 16:37:10 | 显示全部楼层
    Thank u
    发表于 2014-2-10 17:01:51 | 显示全部楼层
  • 签到天数: 1060 天
    发表于 2014-2-12 12:00:45 | 显示全部楼层
    学习一下
    发表于 2014-2-19 16:29:53 | 显示全部楼层
    好东西。
  • 签到天数: 454 天
    发表于 2014-6-29 17:03:24 来自阳光石油论坛手机版 | 显示全部楼层
    学习一下
  • 签到天数: 168 天
    发表于 2015-11-6 23:00:33 | 显示全部楼层
    GMT+8, 2026-6-19 02:24 , Processed in 0.043150 second(s), 23 queries .
