查看: 795|回复: 3
求几篇关于集合卡尔曼滤波的SPE文献
  • 签到天数: 1526 天
    发表于 2014-1-21 15:22:38 | 显示全部楼层 |阅读模式
    1.  A. Bianco, Cominelli, A., Dovera, L., Nzevdal G. and Valles, B. History Matching and Production Forecast Uncertainty by Means of the Ensemble Kalman Filter: a Real Field Application. SPE 10716. 2007.
    2.  Naevdal, G., Johnsen, L.M., Aanonsen, S.I., and Vefring, E.H., Reservoir Monitoring and Continuous Updating Using Ensemble Kalman Filter, SPE 84372. SPE Journal, pp. 66-74, March 2005.
    3.  Chen Y. and Oliver, D. S., Application of Ensemble-Based Closed-Loop Optimization on Brugge Field, SPE paper 118926 presented at the SPE Reservoir Simulation Symposium, The Woodlands, TX, USA, 2-4 February 2009.
    4.  Gu, Y. and Oliver, D. S., An iterative ensemble Kalman filter for multiphase fluid flow data assimilation, SPE Journal, 12(4), 438-446, 2007.
  • 签到天数: 434 天
    发表于 2014-1-21 16:56:28 | 显示全部楼层
    根据序号只找到第二个
    2.pdf
    1.71 MB, 阅读权限: 20, 下载次数: 11
    参与人数 1阳光币 +2 收起 理由
    qqlewis + 2 解疑答惑,帮助他人,只能给2分,不知道为.
    回复 支持 1 反对 0
  • 签到天数: 1526 天
     楼主| 发表于 2014-1-21 16:59:14 | 显示全部楼层
    好啊,很感谢!
  • 签到天数: 26 天
    发表于 2014-1-21 22:48:19 | 显示全部楼层
    可惜我现在没在学校了,帮撸主顶一下
    GMT+8, 2025-5-14 07:02 , Processed in 0.063498 second(s), 31 queries .
