TA的每日心情 | 开心 2014-1-11 00:20 |
签到天数: 38 天 [LV.5]常住居民I
楼主 |
发表于 2013-12-4 13:47:19
显示全部楼层
admin 发表于 2013-12-4 12:56
想请教一下楼主在petrel里的LGR(局部网格加密)之后,如何将加密后的网格一起导出来,输到数值模拟软件里 ...
Export Local Grids to a File
You can export a grid model with or without a local grid set. Only one local grid set can be exported at the same time. To export a set you need to make it active (bold), and it is irrelevant if it is visible or not in a 2D or 3D window. In fact, you can display all local grid sets but only the active one will be exported.
If you want to export a grid without a local grid set, just make sure none of the local sets are active.
1.In the Models tab, select the local grid set you would like to export so it becomes active (bold).
2.Right click on the grid folder, and select export.
3.Select the format ECLIPSE keywords (grid geometry and properties) (ASCII) (*.*) and type the file name.
4.Select the properties you want to export. If you want to export the grid geometry only, uncheck Export properties. Press OK.
5.A window will appear asking for units conversion: You can press OK, or change the units as needed and then press OK.
and in the GRID file, there are some parts like:
CARFIN -- Generated : Petrel
M-2 82 83 53 54 1 10 6 6 30 1 GLOBAL /
ENDFIN -- Generated : Petrel
M-1 100 101 54 55 1 10 6 6 30 1 GLOBAL /
