查看: 3048|回复: 19
[基本理论] 数模十大黄金法则(阿齐兹)
  • 签到天数: 30 天
    发表于 2013-10-25 17:59:33 | 显示全部楼层 |阅读模式
    From Professor Khalid Aziz, Stanford University
    – “Ten Golden Rules for Simulation Engineers”, JPT – November 1989, 1157
    1. Understand Your Problem and Define Your Objectives
    Before you do any simulation:
    • Understand characteristics of reservoir
    • Understand fluids
    • Objective of study clearly stated on paper
    • Ask yourself if the objective are realistic
    2. Keep it Simple
    Start and end with simplest model
    Consistent with
    • the nature of the reservoir
    • Availability of data
    Most sophisticated model available – may not serve your needs
    Understand model limitations and capabilities
    3. Understand Interaction Between Different Parts
    Reservoir not an isolated entity
    Connected to
    • Aquifers
    • Surface facilities
    Separation into different components
          • may be inappropriate – neglects interactions
          • when appropriate – can lead to substantial savings
    4. Don’t Assume Bigger is Always Better
    • Always question size of a study that is limited by the computer
               resources and/or budget
    • Greater number of blocks and components do not automatically
    translate into greater accuracy and reliability (reverse sometimes true)
    5. Know Your Limitations and Trust Your Judgments
    • Remember simulation is not an exact science – more of an art
    • Trust your judgment – based on analysis of the field or lab observations
    • Do simple material balance to check simulation results
    6. Be Reasonable in Your Expectations
    • Don’t try to get from the simulator what it is incapable of producing
    • Remember – if you exclude a mechanism during model development
                 – cannot study its effect with that model
    7. Question Data Adjustments for History Matching
    • Remember HM process does not have a unique solution
    • A good HM with inappropriate adjustments to the data will lead to poor predictions
    • Pay close attention to physical and geological reasonableness
    8. Don’t Smooth Extremes
    • Pay attention to extremes in permeability (barriers and channels)
    • Be careful in the process of averaging
    • Never average out extremes
    9. Pay Attention to the Measurement and Use Scales
    Measurement values at the core scale may not directly apply at larger block
    scale – do influence values at other scales
    • Permeability may be a scalar at some small scale – and a tensor at larger scale
    • Dispersive terms in our equations are a result of process of averaging
    10. Don’t Skimp on Necessary Laboratory Work
    Models do not replace lab experiments
    • designed to understand the nature of the process
    • Or measure essential parameters of the equations being solved
    Plan lab work with its end use in mind
  • 签到天数: 658 天
    发表于 2013-10-25 20:17:39 | 显示全部楼层
    值得好好体会。
  • 签到天数: 1199 天
    发表于 2013-10-26 08:36:47 | 显示全部楼层
    说得多好,跟哲学一样
  • 签到天数: 380 天
    发表于 2013-10-26 09:30:39 | 显示全部楼层
    好好的品味
  • 签到天数: 641 天
    发表于 2013-10-26 09:55:53 | 显示全部楼层
    拜读中。。。。。。
  • 签到天数: 508 天
    发表于 2013-10-26 19:08:03 | 显示全部楼层
    高手给翻译下呗,放在回报里,装下大尾巴狼
  • 签到天数: 30 天
     楼主| 发表于 2013-10-30 21:21:17 | 显示全部楼层
    您就是高手,您以前是学的计算机专业吗?
  • 签到天数: 384 天
    发表于 2013-10-31 15:57:55 | 显示全部楼层
    高手给翻译下呗  看不太懂
  • 签到天数: 1893 天
    发表于 2013-12-13 09:12:17 | 显示全部楼层
    比较精辟,简单的往往是最好的!~~
  • 签到天数: 299 天
    发表于 2013-12-13 18:45:09 | 显示全部楼层
    强烈支持撒,
    GMT+8, 2025-9-10 00:23 , Processed in 0.073245 second(s), 25 queries .
