TA的每日心情 | 奋斗 2013-7-27 00:52 |
签到天数: 59 天 [LV.5]常住居民I
网上有如下翻译:
1,pump blocked
2,pump suffocation
eg:| Pump suffocation happened frequently in Well CCSD-1 during field tests with the φ139. 7 mm wire-line coring tool driven by a mud motor. Such accident happened much less after substituting the mud motor with the normal drill pipe ofφ88. 9 mm. | | 科钻一井φ139.7 mm绳索取心钻具现场试验采用螺杆钻具驱动时出现频繁憋泵的问题,换用φ88.9 mm 普通钻杆后,却很少出现憋泵,而且螺杆钻具本身并没有质量问题。 |
3,building pressure
4,pump pressure building up
5 , Mud pump pack off (来自论坛网友)
不知道那个专业点,憋泵在中文里指钻井中,泵压一直异常的升高, |
