查看: 2202|回复: 4
[ECLIPSE] 关于ECL双重介质的窜流系数
  • 签到天数: 21 天
    发表于 2013-9-9 15:56:02 | 显示全部楼层 |阅读模式
    5阳光币
    file:///C:\Documents and Settings\Administrator\Application Data\Tencent\Users\304410863\QQ\WinTemp\RichOle\DRHR5%MW0LK)8O`A5}0FF5Y.jpg在ECL中处理双重介质模型貌似是裂缝和基岩分层,应该是凯泽米双重介质模型,在技术手册里查到窜流系数TR=CDARCY*K*V*sigma麻烦问下各位大神卡泽米模型中的窜流系数计算公式中的这个CDARCY是什么意思啊??
    最佳答案
    查看完整内容
    CDARCY 单位转换系数 is a unit conversion factor 在不同的单位制中取值不同: = 0.00852702 (E300); 0.008527 (ECLIPSE 100) (METRIC) 米制 = 0.00112712 (E300); 0.001127 (ECLIPSE 100) (FIELD) 英制 = 3.6 (LAB) 实验室 = 0.00864 (PVT-M) PVT 米制单位 The matrix-fracture coupling transmissibility terms that exist between each cell of the matrix grid and the corresponding cell in the fracture grid ar ...
  • 签到天数: 132 天
    发表于 2013-9-9 15:56:03 | 显示全部楼层
    在不同的单位制中取值不同:
    = 3.6 (LAB)  实验室
    grid and the corresponding cell in the fracture grid are proportional to the cell bulk volume,
    being of the form:TR = CDARCY ⋅ K ⋅ V ⋅ σ
    where by default:
    is taken as the X-direction permeability of the matrix blocks (unless PERMMF is also
    specified; see below),
    is the matrix cell bulk volume (note that this is not the pore volume, having no porosity
    factor), and
    is a factor of dimensionality , to account for the matrix/fracture interface area per
    unit volume, that is the size of the blocks in the matrix volume.
    回复
  • 签到天数: 777 天
    发表于 2013-9-9 19:26:51 | 显示全部楼层
    你可以把那篇文章下来看看
    回复
    发表于 2013-9-10 06:09:34 | 显示全部楼层
    CDARCY --- Darcy’s constant
    = 3.6 (LAB)
    = 0.00864 (PVT-M)
    回复
  • 签到天数: 132 天
    发表于 2013-9-11 10:34:59 | 显示全部楼层
    在不同的单位制中取值不同:
    = 3.6 (LAB)  实验室
    where by default:
    factor), and
    回复
    GMT+8, 2026-8-4 01:59 , Processed in 0.035482 second(s), 19 queries .
