查看: 3075|回复: 1
[Petrel资料] Petrel 2011 Mac Address problem
发表于 2013-8-12 18:49:28 | 显示全部楼层 |阅读模式
You need to install the virtual network device called virtnet. Then you can change its MAC address to whatever you want. You can find the virtnet driver here http://www.ntkernel.com/?Products:Network_and_Security:VirtNet. Install it on windows 7 by going device manager -> action -> add legecy hardware -> next -> install the hardware that I manually select -> show all devices -> have disk (and here you select the netVirtNet.inf file) -> next -> next -> finish. Then you can change the MAC adress by going to the new devices ppropeties in device manager.
  • 签到天数: 443 天
    发表于 2013-8-24 20:58:28 | 显示全部楼层
    thank you very much!
    GMT+8, 2025-5-13 21:36 , Processed in 0.069623 second(s), 23 queries .
