查看: 876|回复: 0
[其他软件资料分享] Change Mac Address windows 7
发表于 2013-8-12 18:39:03 | 显示全部楼层 |阅读模式
Go to Start -> Run, type "regedt32" to start registry editor. not "Regedit".
Go to "HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\ Control\Class\{4D36E972-E325-11CE-BFC1-08002BE10318}". Expand the tree. The sub-keys are 4-digit numbers, which represent particular network adapters. You should see it starts with 0000, then 0001, 0002, 0003 and so on.
Find the interface you want by searching for the proper "DriverDesc" key.
Edit, or add, the string key "NetworkAddress" (has the data type "REG_SZ") to add / change the MAC address.
Exit the registry editor
reboot your system
GMT+8, 2025-4-11 09:38 , Processed in 0.113146 second(s), 22 queries .
