查看: 1935|回复: 14
[资料贴] Pressure control during oil well drilling
  • 签到天数: 46 天
    发表于 2013-6-20 22:51:56 | 显示全部楼层 |阅读模式
    DescriptionPorous sedimentary formations penetrated by the rock bit contain fluids such as oil, gas or salt water. If the hydrostatic pressure of the drilling fluid drops below the formation pore pressure, pore fluid will enter the well and “kick” the mud out of the well. To control the pressure while drilling you need to understand the behavior of gas. This book aims at explaining the physics and the engineering approaches behind pressures in the sediments, detection of unstable wellbores, equipments necessary to close and kill the well, killing methods and offshore challenges.
    Content1 Introduction
    1.1 The drilling process
    1.2 Geological sediments
    1.3 About Pressure Control in sedimentary rocks
    1.4 Principle of barriers and safety aspects
    1.5 Scope of this book
    2 Pressure in the sediments
    2.1 Sedimentary pressure prediction models
    2.2 Quantifying formation pressure
    3 Well Control Equipment
    3.1 BOP stack and associated equipment
    3.2 Remote control of the BOP
    3.3 Volumetric unstable well (kicking well)
    3.4 Closing procedure during drilling operations
    3.5 Well barriers during drilling operations
    4 Standard killing methods
    4.1 Surface and bottom pressure of a shut in well
    4.2 Hydraulic friction during killing
    4.3 Killing by means of Driller’s Method
    4.4 The Engineer’s Method and kill sheet
    4.5 Killing when unable to circulate from bottom
    5 Modification of the standard killing method
    5.1 Modification due to narrow pressure window
    5.2 Killing with irregular drill string geometry
    5.3 Best practice while drilling through narrow pressure windows
    6 More realistic gas behavior
    6.1 Transport of gas
    6.2 Wellbore pressure during two phase flow
    6.3 Gas solubility
    7 Special offshore safety issues
    7.1 Low sea temperature
    7.2 Other deep water problems
    7.3 Shallow sands below deep sea water
    8 Gas migration through cement
    8.1 The cement slurry
    8.2 Cementing operations
    8.3 Gas migration
    References
    Nomenclature
    Abbreviations
    Unit conversion factors
    About the AuthorPål Skalle's hjemmeside
  • 签到天数: 972 天
    发表于 2013-6-21 09:45:14 | 显示全部楼层
    要钱不?
    发表于 2013-6-21 09:48:54 | 显示全部楼层
    好资料,谢谢分享
  • 签到天数: 46 天
     楼主| 发表于 2013-6-21 09:51:44 | 显示全部楼层
    zjsyhm 发表于 2013-6-21 09:45
    要钱不?
    不要钱,要阳光币
  • 签到天数: 265 天
    发表于 2013-6-21 10:34:48 | 显示全部楼层
  • 签到天数: 162 天
    发表于 2013-6-21 13:34:19 | 显示全部楼层
  • 签到天数: 162 天
    发表于 2013-6-21 13:36:12 | 显示全部楼层
  • 签到天数: 18 天
    发表于 2013-6-22 14:13:56 | 显示全部楼层
    资料不错,已下载
  • 签到天数: 12 天
    发表于 2013-6-22 23:54:07 | 显示全部楼层
    ok,good
  • 签到天数: 237 天
    发表于 2013-7-6 17:15:32 | 显示全部楼层
    看看!!!!
    GMT+8, 2025-7-20 05:19 , Processed in 0.061824 second(s), 27 queries .
