查看: 1967|回复: 6
[Petrel资料] Petrel 2012 Reservoir Engineering
  • 签到天数: 443 天
    发表于 2013-5-9 16:45:06 | 显示全部楼层 |阅读模式
    Petrel 2012 Reservoir Engineering ,来自于斯伦贝谢官网
    Petrel_2012_reservoir_engineering.pdf
    3.11 MB, 下载次数: 161
    售价: 1 阳光币  [记录]
    发表于 2013-5-9 17:23:58 | 显示全部楼层
    我也是坐沙发的
  • 签到天数: 684 天
    发表于 2013-5-10 07:59:31 | 显示全部楼层
    是个介绍性的
  • 签到天数: 196 天
    发表于 2013-6-25 13:58:07 | 显示全部楼层
    幸好没下载
  • 签到天数: 109 天
    发表于 2015-2-7 22:38:17 | 显示全部楼层
    放心安装,同时运行,没问题的。
  • 签到天数: 117 天
    发表于 2017-1-6 10:54:27 | 显示全部楼层
    958.7958.7958.7
  • 签到天数: 117 天
    发表于 2017-1-6 11:52:01 | 显示全部楼层
    A compositional fluid model represents the hydrocarbon fluid by a
    set of components (typically 6-12 for reservoir simulation). An equation
    of state is then used to determine the physical properties of mixtures of
    these components as a function of pressure and temperature and the
    properties of the individual components
    GMT+8, 2025-4-24 19:13 , Processed in 0.057980 second(s), 27 queries .
