查看: 1233|回复: 4
翻译求助
  • 签到天数: 298 天
    发表于 2013-3-20 23:13:35 | 显示全部楼层 |阅读模式
    近日看到一篇文献,其中的defending fluid、filling event不知怎么翻译,大家有知道的吗?谢谢了!
  • 签到天数: 777 天
    发表于 2013-3-21 08:40:51 | 显示全部楼层
    顶一下
  • 签到天数: 164 天
    发表于 2013-3-21 10:41:31 | 显示全部楼层
    最好给一段话或者几句话!
    单独词的话不好翻译诶!
  • 签到天数: 298 天
     楼主| 发表于 2013-3-21 18:08:58 | 显示全部楼层
    tianyingzuonb 发表于 2013-3-21 10:41
    最好给一段话或者几句话!
    单独词的话不好翻译诶!
    This keyword controls the accuracy at which the incremental water saturation target is reached. It is generally not feasible to calculate water saturation after each filling event, as that would be computationally very expensive. When starting a new saturation step, an approximate number of required filling events is estimated. This estimate is however quite uncertain as the water saturation does not vary linearly with the number of filling events.
    This keyword will change the target saturation interval, specified by entry 3 in SAT_TARGET, once relative permeability of the defending fluid drops below a specified threshold.
    发表于 2013-3-31 16:40:06 | 显示全部楼层
    没人回帖。。。我来个吧
    GMT+8, 2025-5-15 08:05 , Processed in 0.053568 second(s), 23 queries .
