How complex is my reservoir? How much oil is in place? Where should I drill my next well? With RMS™ – the industry’s most integrated and powerful geo-modelling solution you are able to gain more knowledge about fields than ever before. Knowledge which will help you increase the recovery rates and optimise the econom
RMS Workflow Roxar's integrated RMS™ solution can help accelerate the field development planning cycle by allowing multiple disciplines to work together on a common reservoir model in parallel. RMS breaks down the barriers between geoscientists and engineers resulting in better decisions through a shared understanding of the reservoir. RMSfacilitate big loop workflows of reservoir management, that provide the greatest accuracy, the most comprehensive uncertainty assessment, and the best-quantified risk in the geologic model - from seismic acquisition through to simulation and from exploration to production.
