查看: 3288|回复: 2
[CMG] 求助:CMG运行时提示内存不够的问题
  • 签到天数: 261 天
    发表于 2013-1-16 22:10:14 | 显示全部楼层 |阅读模式
    模型有37万个网格,运行时提示内存不够。电脑系统为XP32位,内存2G,虚拟内存已改为4G。详细报告如下:SOLVINT是什么意思怎么占用那么多内存?
    ================ WARNING (from subroutine: INIT0)  ======================
      Unphysical water mole fractions were adjusted in a total of 246090 blocks.
      See output file for details for selected blocks.
    ERROR:  Memory allocation failure for array 'vq' in section 'solvint' for 366190104 bytes
    The following summaries will help you find the reason for
    the allocation error.  The most common reason is that this
    data requires more swap space (virtual memory) than is
    available on this computer at this time.  To get a summary
    of dimension parameters generated by your data use keywords
    *DIM *DIMSUM in the I/O Control section or command-line
    argument "-dimsum".
                              Global Storage Usage
                 Section           Bytes          Mbytes   # Objects
                 SOLVINT       823002340         784.876          87
                   STARS       473812836         451.863         637
                  GRMOD0       212046432         202.223         220
                  GRMOD1        79875848          76.176         131
                 AQUIFER        58099516          55.408          19
                   POINT        31167452          29.724          79
                   PRTCM         7079310           6.751          17
                 RELPERM         1988644           1.897         167
                  SECTOR         1969280           1.878          43
                  WMCOM1          973338           0.928         910
                    WELL          770788           0.735         220
                  SR2COM          402144           0.384          79
                ELECTRIC           68356           0.065          27
                  KWCOM1           35207           0.034          43
               GLOBSTORE            7474           0.007          27
                    VISC            6076           0.006          45
                  WELHYD            2152           0.002          44
                   REACT            1892           0.002          73
                 CMGFILE            1133           0.001          16
                  PGMCH1            1048           0.001         170
                    KVAL             600           0.001          40
                  SR2WRT             280           0.000          18
                 PSOLINT             204           0.000          47
                 GEOMECH             180           0.000          39
                   PGAIM             148           0.000          35
                  GRMOD2             116           0.000          29
                  ADSORP              52           0.000          13
                  ABAQUS              28           0.000           6
                  WMCOM2              24           0.000           6
                  PGMCH2              12           0.000           3
                 COMPACT               8           0.000           2
                  INGRDM               0           0.000           0
                   Total      1691312918        1612.962        3292
    Dimensioning Parameters
             379620  MDPTSS - Matrix blocks, including nulls
             379620  MDPTCS - Total blocks, including nulls
             246090  MDPTPS - Total non-null blocks
                  1  MDPTGN - Grids (fundamental & refined)
                  1  MDNVAM - Sets of Volume/area modifiers
            1518482  MDNEXF - Exterior block faces
             708685  MDPTBC - Total interblock connections
                  5  NCOMP  - Total components (fluid & solid)
                  5  NUMY   - Fluid components
                  5  NUMX   - Condensable components
                  6  NFLOW  - Flowing items (fluids + energy)
                  0  NSLD   - Solid components
                  1  NTHSET - Compressibility/thermal sets
                  1  NKROCK - Rel perm rock sets
                  1  NKRSET - Rel perm table sets
                  7  MDNEQ  - Equations per block
             246124  MDSOL  - Solver elements (blocks+wells+1)
            1722630  MDNEQT - Total grid equations
             709071  MDPTCN - Interblock & block-well connections
                 31  MDNOR  - Orthogonalizations + 1
              61531  MDJCM  - Connections per equation with fill
            2127214  MDCALP - Submatrices in the Jacobian matrix
           59534558  MDALP  - Size of Jacobian off-diagonal
           12058443  MDALD  - Size of Jacobian diagonal
            1722663  MDBET  - Size of RHS and solution vectors
            1476573  MDV    - Size of solution vector
            8859273  MDDD   - Diagonal entries
             430717  MDROW  - Columns per equation
            2127214  MDICLU - 1 + Block entries in each of L & U
                  0  MDLU   - Size of each of L & U
            3015019  MDPROW - Size of PARASOL list arrays
              61531  MDPJCM - PARASOL row storage parameter
                    WM parameters - Dimensioner output
       mdwell =            33
       mdlayr =           386
       mdly1w =            43
       mdlypl =             1
       mdgrup =             2
       mdrgrp =             1
       mdcons =             4
       mdhyvl =             1
       mdbhen =           100
       mdhytb =             1
       mdcygr =             1
       mdcygp =             1
       mdcygs =             1
       mdcsgr =             1
       mdgcms =            40
       mdwcms =           400
  • 签到天数: 9 天
    发表于 2013-1-22 00:04:30 | 显示全部楼层
    虚拟内存再大也没用,32位系统无解,换64位系统和64位CMG。楼主如果有64位的cmg分享我一个。。。
    ggdatafile@gmail.com
  • 签到天数: 132 天
    发表于 2018-8-27 16:03:14 | 显示全部楼层
    请问最后您是怎么解决这个问题的啊?
    GMT+8, 2025-7-9 17:34 , Processed in 0.049854 second(s), 19 queries .
