查看: 7286|回复: 8
[钻井软件资料] sysdrill 2012 新功能介绍
  • 签到天数: 918 天
    发表于 2012-11-30 20:46:19 | 显示全部楼层 |阅读模式
    Paradigm™ Sysdrill® 2012, the latest version of Paradigm’s well planning and drilling engineering software package, was developed with the product’s expanding user base in mind, and contains numerous customer-driven functionality enhancements. Compatible with the Paradigm Epos® 4.1 infrastructure, Sysdrill 2012 delivers significant performance improvements, especially for large data sets.
    Some of the salient features of the new release are:
    Well Planning & Survey Management
    Survey management T-plots
    • Survey management T-plots
    • Manual project ahead mode and plan vs. actual for projection
    • Real-time survey mode
    • ISCWSA updates to Revision 3 + widely adopted extensions to the ISCSWA standard
    • New graphs for survey management
    • Survey tool import/export
    • New map projections
    Drilling Engineering • Improved bottom hole assembly (BHA) diagrams
    • Additional BHA parameters for Torque & Drag and Hydraulics
    Torque & Drag
    Swivel tool
    • True tension calculation
    • Applied pressure support
    • Stretch & twist plots
    • Drag and standoff plots
    • Modeling of swivel and tractor tools
    • Post-buckling stress and length change calculations
    • Hole configuration added to calculation results
    Hydraulics • Managed pressure calculations
    • Split flow support for Hydraulics & swab surge
    • Improved swab surge calculations
  • 签到天数: 11 天
    发表于 2012-12-1 10:18:31 | 显示全部楼层
    没看懂。。。。。。。
  • 签到天数: 918 天
     楼主| 发表于 2012-12-3 22:18:10 | 显示全部楼层
  • 签到天数: 918 天
     楼主| 发表于 2012-12-3 22:19:58 | 显示全部楼层
    发表于 2013-3-20 22:24:32 | 显示全部楼层
    你好,能加你为QQ好友吗?519382549  验证:杨光磊
    很想学习你的sysdrill2012
    发表于 2015-10-29 14:12:02 | 显示全部楼层
    你好,可以加你吧,一起学习一下啊
  • 签到天数: 174 天
    发表于 2016-3-24 18:00:58 | 显示全部楼层
    有没有软件
  • 签到天数: 637 天
    发表于 2016-8-6 00:12:11 | 显示全部楼层
    没看懂。
    2017-3-17 10:04
  • 签到天数: 26 天
    发表于 2017-3-28 14:20:15 | 显示全部楼层
    嗯嗯嗯嗯
    GMT+8, 2025-4-13 00:46 , Processed in 0.082418 second(s), 27 queries .
