查看: 1165|回复: 3
The Earth as a seismic absorption band——Science文献求助
    发表于 2012-8-30 19:31:29 | 显示全部楼层 |阅读模式
    10阳光币
    【题目】The Earth as a seismic absorption band
    【摘要】
                Attenuation of seismic waves indicates that the earth is not perfectly elastic. Dispersion accompanying absorption gives frequency-dependent "elastic" moduli, a fact that must be taken into account when inverting seismic data. Normal mode data are reinverted after correcting for absorption. The correction removes the discrepancy between body wave and free oscillation interpretations of earth structure.
    最佳答案
    查看完整内容
    看看是不是这个!
  • 签到天数: 105 天
    发表于 2012-8-30 19:31:30 | 显示全部楼层
    看看是不是这个!
    The Earth As a seismic absorption band.pdf
    246.74 KB, 下载次数: 10
    回复
     楼主| 发表于 2012-8-31 10:49:00 | 显示全部楼层
    没人帮忙呢?
    回复
     楼主| 发表于 2012-10-14 20:54:22 | 显示全部楼层
    光之翼 发表于 2012-9-10 19:02
    看看是不是这个!
    感谢!!!就是这个
    回复
    GMT+8, 2025-5-19 13:01 , Processed in 0.058179 second(s), 21 queries .
