TA的每日心情 | 擦汗 2014-7-18 20:58 |
签到天数: 42 天 [LV.5]常住居民I
楼主 |
发表于 2012-8-13 14:20:06
显示全部楼层
SPE标题:Water Fracs and Sand Quantity: A Barnett Shale Example
摘要:Chief Oil and Gas, LLC has an active drilling and completion
program in the Barnett Shale, Newark East Field, Ft Worth
Basin near Ft Worth, Texas, USA. This Mississippian age gas
producing reservoir consists of naturally fractured shale. Most
hydraulically induced fractures have been observed to be more
of a network of fractures, referred to as fracture fairways, than
the usual ‘planar’ fractures. These fairways apparently result
from opening many of the natural fractures allowing for
production. All wells must be hydraulically fractured for
economic production. The Barnett Shale hydraulic fracturing
trend in the last few years has been to water frac with small
concentrations of sand. The water frac treatments reported on
here have varied from approximately 600,000 to over
1,500,000 gallons and 120,000 to over 400,000 pounds of
sand. Most of the wells have been completed in the lower
Barnett with a lesser number in the upper and lower. Results
from both types of completions are included in this work.
Production histories versus treatment volume and pounds of
sand are presented as well as production decline data. Results
indicate a much better correlation of production history with
sand quantity than with fluid volume.
A Barnett Shale Example.pdf
(366.26 KB, 下载次数: 6, 售价: 1 阳光币)
