查看: 1117|回复: 5
Looking for (Sr.) Process Engineers
发表于 2012-7-7 02:22:27 | 显示全部楼层 |阅读模式
Education and Experience
At least a BSc degree;
At least 3 years experience in the Oil & Gas industry;
Fluently in English;
Age before 30 or after 35 is better.
Summary of Conditions
Hours a week     40
Starting Date     Asap
The work location Holand
Description
We are looking for (Sr.) Process Engineers in several areas in the Oil & Gas industry:
-       Upstream
-       Downstream
-       Onshore
-       Offshore
Are you a Process Engineer with experience in the Oil & Gas industry, please feel free to send us your resume. We are more than willing to reply to you with more information about the available positions. The information below might give you an idea about what we require.
Responsibilities
 楼主| 发表于 2012-7-7 02:23:03 | 显示全部楼层
Responsibilities
 楼主| 发表于 2012-7-7 02:23:55 | 显示全部楼层
Responsibilities
  • 签到天数: 72 天
    发表于 2012-7-7 12:19:46 | 显示全部楼层
    看不懂啊!
     楼主| 发表于 2012-7-7 14:26:33 | 显示全部楼层
    孙广晨 发表于 2012-7-7 12:19
    看不懂啊!
    不好意思,网络有问题没发全,
    需要应聘的朋友发简历到我邮箱,helomin@hotmail.com
    资料补上:
    Responsibilities
    * Implements, modifies, and maintains chemical processes;
    *Calculates and organizes data for process flow sheets including instrumentation and control considerations;
    *Models processes and units operations;
    * Ensures proper sequence of operation;
    *Prepares specifications and operating instructions for processing equipment;
    *Develops process flow diagram to define heat and material balance;
    *Develops process specifications, e.g. distillation columns, pressure vessels, pumps, compressors, heat   exchangers, and fired heaters;
    *Participates in planning, cost development and management, and scheduling for assigned projects;
    *Directs activities to ensure that construction, installation, and operational testing conform to functional specifications, recognized codes and standards, and customer requirements;
    *Maintains effective communication with project team members and with the customer.
    Interested?
    Are you interested in applying for this position? Please contact me:
    helomin@hotmail.com
    GMT+8, 2025-4-29 17:19 , Processed in 0.044970 second(s), 18 queries .
