查看: 1036|回复: 0
Resistance torque Casing Prevent Torsional Casing
发表于 2012-6-7 10:29:32 | 显示全部楼层 |阅读模式
Prevent Torsional Casing Is the basic requirement to rotate the casing cementing. Shengli Oilfield has a full range of cement head to the casing toolIs the basic requirement to rotate the casing cementing. Shengli Oilfield has a full range of cement head to the casing tool。Contact:In here Reply or QQ2466420026
GMT+8, 2026-4-17 16:39 , Processed in 0.078373 second(s), 19 queries .
