查看: 1778|回复: 0
[VBA] Gas rate is calculated using Texas A & I model
  • 签到天数: 54 天
    发表于 2012-6-6 11:37:47 | 显示全部楼层 |阅读模式
    Similar to previous tool, this tool is useful when you want to estimate gas rate by increasing choke size during a welltest program. Suppose you want to test your gas well using separator test. You want to produce your well up to 100 MMscf/d.
    Unfortunately, your separator test is limited to produce gas up to 30 MMscf/d. Using this tool you can predict your gas rate by changing the choke size. Gas rate is calculated using Texas A & I model.
    Calculate_Gas_Rate_Using_Choke_Equation_Texas_A__I_Model.zip
    14.59 KB, 下载次数: 10
    售价: 5 阳光币  [记录]
    GMT+8, 2026-6-7 14:46 , Processed in 0.045292 second(s), 24 queries .
