查看: 1377|回复: 0
[VBA] Calculate_Gas_Rate_Using_Choke_Equation_Schlumberger_Model
  • 签到天数: 54 天
    发表于 2012-6-6 11:34:31 | 显示全部楼层 |阅读模式
    This tool is useful when you want to estimate gas rate by increasing choke size during a welltest program. Suppose you want to test your gas well using separator test. You want to produce your well up to 100 MMscf/d.
    Unfortunately, your separator test is limited to produce gas up to 30 MMscf/d. Using this tool you can predict your gas rate by changing the choke size. Gas rate is calculated using Schlumberger model.
    To calculate gas rate, follow the following steps:
    • Calculate C coefficient from welltest data.
    • Plot Choke Size vs. C coefficient calculated above.
    • Generate correlation of  C coefficient as a function of Choke Size using Excel trendline.
    • Re-calculate C coefficient using above correlation.
    • Calculate gas rate using new calculated C correlation.
    Calculate_Gas_Rate_Using_Choke_Equation_Schlumberger_Model.zip
    47.7 KB, 下载次数: 3
    售价: 10 阳光币  [记录]
    GMT+8, 2025-6-6 12:37 , Processed in 0.051408 second(s), 24 queries .
