查看: 971|回复: 0
【北京猎头职位】某石油外资企业招聘Geomodeler
发表于 2012-5-18 16:23:15 | 显示全部楼层 |阅读模式
岗位职责
* Work as part of a multidisciplinary team such as geologists, geophysicists and petrophysicist in a wide variety of projects (including single well interpretation, exploratory play evaluation, integrated reservoir studies and field development planning.
* Conduct all tasks related to building complex geologic models
* Translate various types of data into representative Geologic Model that can be used for developing the field.
* Design and prepare geological reservoir studies aimed at constructing and/or improving geological 3D static models.
* Conduct facies and petrophysical properties modeling process.
* Conduct the uncertaintyanalysis for the STOOIP &; reservoir properties.
* Contribute with the team and together with the client, on developing field development plan.
* Construct DFN modeling&; using micro-seismic data for discrete fracture modeling.
岗位要求
学历要求:全日制统招本科或以上
性别要求:不限
语言要求:英语 + 普通话
专业要求:不限
年龄要求:30-45
总工作年限:5年以上
任职资格的具体描述:
* Bachelor degree in a relevant Geological or Engineering Discipline.
* Good command of commercial software packages such as RMS and Petrel.
* Strong regional geology, structural geology and sedimentary background.
* Good understanding of well testing, geophysics, RFT, core analysis, petrophysical fields.
* Good understanding of Stochastic modeling methods and deterministic modelingmethods.
* Understand the likely geometry, lateral continuity and reservoir quality of sandbodies in the reservoir.
* Understanding the techniques and workflows used to build models, and how the results are used by reservoir engineers
薪酬福利
职位年薪:30-40万
薪资构成:底薪 + 提成
年假福利:国家标准
社保福利:国家标准 + 商业保险
居住福利:公积金
有意者请发简历到:ruby.wang@reliance-hr-international.com
GMT+8, 2025-7-16 19:03 , Processed in 0.048078 second(s), 19 queries .
