查看: 54771|回复: 222
[散阳光币]热烈祝阳仔zhangcm@126.com发一篇SCI收录PAPER
  • 签到天数: 418 天
    发表于 2012-5-5 11:43:56 | 显示全部楼层 |阅读模式
    题目:Maturity effect on carbazole distributions in source rocks from the saline lacustrine settings, the western Qaidam Basin, NW China
    作者:Chunming Zhang , Yuqing Zhang, Chunfang Cai
    刊物:Journal of Asian Earth Sciences
    摘要:Carbazole distributions and biomarker compositions have been investigated in a series of source rocks
    from the Tertiary strata in the western Qaidam Basin, NW China. Typical biomarker signatures, high gam-macerane, high C 35 hopane and low Pr/Ph, indicate a saline lacustrine environment. Maturity parameter C29
    sterane aaa S/S + R ranges from 0.06 to 0.58, indicating immature (ca. <0.35) and mature (ca. >0.35)
    stages. Significant variations were observed for carbazole distributions with maturation. As for C1-carb-azoles, the relative amounts of 1-MC (methylcarbazole) show a decrease trend in the immature stage and an increase trend in the mature stage, while the other three isomers (2-, 3- and 4-MCs) show a generally opposite change, indicating a ‘‘two-stage’’ variation. As for C2-carbazole isomers, complex variations were observed for their relative amounts, an overall increase for 1,7-DMC (dimethylcarbazole), a slight ‘‘two-stage’’ change for 1,8- and 1,3-DMCs and a marked ‘‘two-stage’’ variation for 2,4-, 2,5- and 2,6-DMCs.Comparison of the distributions of carbazole and benzocarbazoles revealed a preferential generation for benzocarbazoles at high maturity levels. Benzocarbazole ratio a/a + c varies only in a narrow range 0.52–0.61 in the entire maturity range, suggesting limited maturity dependence. The results here support the idea that carbazole distributions have strong maturity effect in a wide maturity range and the ‘‘two-stage’’ variations for some pyrrolic nitrogen isomers may indicate their different geochemical controls between the immature and mature stages.
    论坛用户名:zhangcm@126.com
    热烈祝贺阳光石油论坛会员zhangcm@126.com发一篇SCI,阳光石油论坛散阳光币500,奖励zhangcm@126.com阳光币100,大家在楼下回复。每楼阳光+5,散完为止。每个会员加阳光币一次。
    大家可以多多咨询
    zhangcm@126.com如何发高水平的文章。也希望zhangcm@126.com能够抽时间整理自己发文献以来的心得。
    有效领取时间从本贴起一周时候,一周后自动取消发放。
  • 签到天数: 87 天
    发表于 2012-5-5 11:45:56 | 显示全部楼层
    沙发  恭喜啊 我要是也能发一篇就爽了 呵呵
    参与人数 1阳光币 +5 收起 理由
    yushan + 5 感谢回复
  • 签到天数: 110 天
    发表于 2012-5-5 11:48:25 | 显示全部楼层
    板凳!恭喜了~~~呵呵。。。太帅了额!
    参与人数 1阳光币 +5 收起 理由
    yushan + 5 感谢回复
  • 签到天数: 418 天
     楼主| 发表于 2012-5-5 11:49:12 | 显示全部楼层
    我也回复一下,向zhangcm@126.com学习,致敬!
    参与人数 1阳光币 +5 收起 理由
    badboy0504 + 5 我给你加上
  • 签到天数: 261 天
    发表于 2012-5-5 11:49:19 | 显示全部楼层
    回帖奖励 +5 阳光币
    强烈建议zhangcm@126.com发喜糖,哈哈!
  • 签到天数: 360 天
    发表于 2012-5-5 11:49:52 | 显示全部楼层
    恭喜,哈哈。
    参与人数 1阳光币 +5 收起 理由
    yushan + 5 感谢回复
  • 签到天数: 787 天
    发表于 2012-5-5 11:51:34 | 显示全部楼层
    支持加祝贺
    参与人数 1阳光币 +5 收起 理由
    yushan + 5 感谢回复
  • 签到天数: 418 天
     楼主| 发表于 2012-5-5 11:52:20 | 显示全部楼层
  • 签到天数: 455 天
    发表于 2012-5-5 11:52:31 | 显示全部楼层
    回帖奖励 +5 阳光币
    有我的吗
  • 签到天数: 72 天
    发表于 2012-5-5 11:55:39 | 显示全部楼层
    强烈建议zhangcm@126.com每人发500阳光币哈哈!
    参与人数 1阳光币 +5 收起 理由
    yushan + 5 感谢回复
    GMT+8, 2026-8-6 03:38 , Processed in 0.040858 second(s), 28 queries .
