查看: 29764|回复: 313
[Petrel资料] petrel 2010操作手册-essca
  • 签到天数: 524 天
    发表于 2012-4-24 14:56:34 | 显示全部楼层 |阅读模式
    目 录
    第一章 Petrel简介...........................................................................................................................1
    1.1 关于本手册........................................................................................................................1
    1.2 Petrel Workflow Tools功能简介.........................................................................................2
    1.3 安装并启动Perel ...............................................................................................................3
    1.4 Perel用户界面简介............................................................................................................4
    1.5 菜单及工具条....................................................................................................................6
    第二章常用工具及基本操作.........................................................................................................7
    2.1 Petrel资源管理器...............................................................................................................7
    2.2 流程管理器........................................................................................................................7
    2.3 显示窗口............................................................................................................................8
    2.4 数据信息............................................................................................................................8
    2.5 可视化..............................................................................................................................10
    2.6 设置色彩、线宽等..........................................................................................................11
    2.7 定义一个横截面(General Intersection)...........................................................................12
    2.8 定义Vertical Well Section ...............................................................................................13
    2.9 数据准备..........................................................................................................................14
    2.9.1 Perel数据类型介绍................................................................................................14
    2.9.2 具体的数据格式例子...........................................................................................15
    2.10 数据输入........................................................................................................................20
    练习2-1 创建一个工区..............................................................................................21
    练习2-2 加载井数据..................................................................................................21
    练习2-3 加载分层数据..............................................................................................25
    练习2-4 加载地震数据..............................................................................................26
    练习2-6 地震剖面/切片显示.....................................................................................37
    练习2-7 加载地震解释数据......................................................................................39
    2.11 编辑整理数据................................................................................................................41
    2.11.1 自动生成断层多变形.........................................................................................41
    2.11.2 生成/编辑Polygons.............................................................................................43
    2.11.3 生成/编辑Surface................................................................................................44
    2.11.4 面体积计算.........................................................................................................46
    2.12 井数据的管理................................................................................................................47
    2.12.1 归类引擎(Saved searches)..............................................................................48
    2.12.2 井滤波(well filter) ..........................................................................................49
    2.13 计算器介绍(Calculator) ...........................................................................................50
    2.14 工区恢复........................................................................................................................54
    2.15 建立几何模型................................................................................................................55
    2.16 离散化测井曲线与数据分析........................................................................................55
    2.17 Data analysis(数据分析) ........................................................................................56
    第三章聚类分析与井相关...........................................................................................................60
    3.1 属性(地震、测井)聚类分析和判断..........................................................................60
    3.2 井相关(Well Correlation) ...........................................................................................67
    3.3 剖面的制作......................................................................................................................77
    3.3.1 产生一个用于做剖面的Polygon..........................................................................77
    3.3.2 作任意剖面...........................................................................................................77
    3.3.3 过井剖面...............................................................................................................78
    第四章地震解释与属性提取.......................................................................................................80
    4.1 合成地震记录................................................................................................................80
    4.2 地震属性提取、地震资料解释和构建速度模型........................................................92
    练习4-1 地震属性提取............................................................................................97
    练习4-2 地震资料解释............................................................................................99
    第五章域转换与遗传反演.........................................................................................................106
    5.1 构建速度模型..............................................................................................................106
    5.2 时间-深度转换............................................................................................................109
    5.3 遗传反演......................................................................................................................109
    第六章框架模型......................................................................................................................... 111
    6.1 Process Diagram流程简介........................................................................................... 111
    6.2 构造模型........................................................................................................................113
    6.2.1 Fault Modeling.....................................................................................................114
    6.2.2 Pillar Gridding......................................................................................................120
    6.2.3 vertical layering(建立垂向网格框架)............................................................125
    6.3 Petrel构造框架(Structural FrameWork)....................................................................132
    6.3.1 建立构造框架模型..............................................................................................133
    6.3.2 与解释同步的断层建模.....................................................................................143
    6.4 使用构造框架建模技术建立地质单元模型................................................................145
    第七章相建模(Facies Modeling)..........................................................................................149
    7.1 Petrel2010 版本中相建模技术的大发展.......................................................................149
    7.2 Petrel2010 版本中多点统计地质学模拟方法...............................................................150
    7.2.1 技术发展..............................................................................................................150
    7.2.2 多点地质统计学的原理......................................................................................152
    7.2.3 多点地质统计学模拟方法操作.........................................................................154
    7.2.4 自定义目标体.....................................................................................................158
    7.2.5 训练图像和训练模式.........................................................................................159
    7.3 概率趋势模拟.................................................................................................................161
    7.4 Petrel2010 版本中基于目标模型的条件模拟...............................................................163
    7.5 Petrel2010 版本中的序贯指示模拟...............................................................................167
    7.6 多级相控建模................................................................................................................169
    7.7 截断高斯趋势相建模和截断高斯模拟........................................................................171
    7.8 交互式相建模................................................................................................................172
    7.9 其它相建模方法............................................................................................................174
    7.10 局部模型更新...............................................................................................................178
    第八章裂缝建模.......................................................................................................................180
    8.1 裂缝数据准备................................................................................................................180
    8.2 裂缝性质分析................................................................................................................181
    8.3 裂缝信息单井剖面建立................................................................................................181
    8.4 裂缝参数确定及预测....................................................................................................183
    8.5 裂缝几何模型建立........................................................................................................186
    8.6 等效介质(孔、渗)模型建立....................................................................................186
    8.7 确定性裂缝建模............................................................................................................188
    8.8 练习:如何建立一个标准的裂缝建模流程................................................................189
    第九章油藏属性建模.................................................................................................................192
    9.1 Moving average滑动平均模拟.......................................................................................192
    9.2 序贯高斯模拟................................................................................................................193
    9.3 相控模拟........................................................................................................................195
    9.4 有趋势约束的模拟........................................................................................................196
    9.5 高斯随机模拟................................................................................................................197
    第十章模型粗化与输出输入.....................................................................................................199
    10.1 模型粗化......................................................................................................................199
    10.1.1 创建粗化网格...................................................................................................199
    10.1.2 Scale Up Structure ..........................................................................................200
    10.1.3 Scale Up Properties .........................................................................................200
    10.2 局部网格加密..............................................................................................................201
    10.3 模型输出......................................................................................................................202
    10.4 模型输入......................................................................................................................205
    第十一章构造与断层封堵性分析.............................................................................................207
    11.1 构造和断层分析流程(Structural and fault analysis) .............................................208
    11.2 构造分析....................................................................................................................209
    11.2.1 构造分析在3D地震层面解释(和相关属性)中的应用............................209
    11.2.2 构造分析在地质模型中的应用.......................................................................215
    11.2.3 构造和断层分析流程——断层封堵性计算...................................................220
    第十一章储量计算和井轨迹设计.............................................................................................226
    11.1 Well Design...................................................................................................................226
    11.2 储量计算......................................................................................................................229
    第十二章成果出图.....................................................................................................................233
    12.1 绘制平面图(Map Window)....................................................................................233
    12.2 测井曲线标签..............................................................................................................234
    12.3 多边形内属性充填......................................................................................................236
    12.4 绘制截面图(Intersection Window) ........................................................................238
    12.5 Function Window..........................................................................................................240
    12.6 蒙太奇绘图..................................................................................................................241
    附录Ⅰ:Petrel 2010 数据输入/输出类型表......................................................................243
    附录Ⅱ:Petrel建模常用术语英汉对照..............................................................................248
    参与人数 1阳光币 +5 收起 理由
    admin + 5 精品资料,感谢楼主
  • 签到天数: 249 天
    发表于 2012-4-24 15:37:33 | 显示全部楼层
    @超级版主@版主@阳光顾问@安达尔顿这个非常齐全的petrel基础培训资料啊。谢谢楼主!
  • 签到天数: 418 天
    发表于 2012-4-24 15:55:24 | 显示全部楼层
    感谢楼主的分享!
  • 签到天数: 524 天
     楼主| 发表于 2012-4-24 16:12:35 | 显示全部楼层
    资源共享,共同进步
  • 签到天数: 443 天
    发表于 2012-4-24 16:58:45 | 显示全部楼层
    很不错啊,多谢!!
  • 签到天数: 364 天
    发表于 2012-4-24 17:03:18 | 显示全部楼层
    感谢楼主分享
  • 签到天数: 214 天
    发表于 2012-4-24 18:41:02 | 显示全部楼层
    感谢楼主的分享!
  • 签到天数: 653 天
    发表于 2012-4-24 18:52:24 | 显示全部楼层
    学习一下
  • 签到天数: 137 天
    发表于 2012-4-24 19:10:20 | 显示全部楼层
    感谢楼主的分享!
  • 签到天数: 997 天
    发表于 2012-4-24 20:26:49 | 显示全部楼层
    好东西啊
    GMT+8, 2025-5-22 13:13 , Processed in 0.093125 second(s), 27 queries .
