查看: 1666|回复: 0
【国外硕士】Stability Criteria for the Thermal Adaptive Implicit Method
  • 签到天数: 435 天
    发表于 2012-3-6 10:45:56 | 显示全部楼层 |阅读模式
    Title:Stability Criteria for the Thermal Adaptive Implicit Method
    Author:Anshul Agarwal
    Year:2005
    Degree:MS
    Abstract:
    The stability criteria for thermal reservoir displacements are derived using Von Neumann analysis. It is shown that when reduced to the isothermal form, we recover the stability conditions presented by Coats [5], [6]. The derived stability criteria are tested by violating the time step size in a 1-D, oil-water thermal simulator coded using MATLAB. The stability criteria can be used to decide the time step size for an IMPEST (implicit in pressure, explicit in saturation and temperature) formulation. The criteria account for explicit treatment of capillary pressure, viscous forces, and heat convection and conduction terms. The criteria can be used as a switching rule in an adaptive implicit thermal model.
    Stability Criteria for the Thermal Adaptive Implicit Method.pdf (430.89 KB, 下载次数: 0, 售价: 5 阳光币)
    GMT+8, 2026-6-19 02:27 , Processed in 0.064564 second(s), 28 queries .
