查看: 2420|回复: 7
求“微地震压裂软件”
  • 签到天数: 17 天
    发表于 2012-3-5 08:10:17 | 显示全部楼层 |阅读模式
    请问哪问大虾在研究微地震压裂监测技术呢,有没有什么软件呢?
    参与人数 1阳光币 +1 收起 理由
    lovecost + 1 大哥 软件是要钱的
  • 签到天数: 918 天
    发表于 2013-8-30 09:34:26 | 显示全部楼层
    InSite is an integrated seismic data acquisition, processing, management and visualisation software for seismological studies ranging in scale from acoustic emissions in the laboratory, through microseismics around underground excavations up to regional-scale earthquakes. InSite software is used extensively in ASC’s consulting operations, and is now used by many international organisations for in-house processing and management of microseismic data.
    The software is independent of acquisition hardware. It can be integrated with hardware packages to perform real-time data capture and processing. There is a wide range of standard tools and advanced processing tools.
    发表于 2013-11-30 14:11:11 | 显示全部楼层
    phoenixkiller 发表于 2013-8-30 09:34
    InSite is an integrated seismic data acquisition, processing, management and visualisation software  ...
    你好,请问这个软件怎么样,对于微地震压裂解释,期待你的回复
    2014-6-7 14:31
    发表于 2014-7-18 23:16:42 | 显示全部楼层
    解释主要靠地球物理、地质、岩石力学、岩石物理、石油工程等多专业来合作讨论。
    发表于 2014-9-15 18:48:06 | 显示全部楼层
    目前市面上也就只有一款InSite软件出售,价格在10w人民币左右。但只能处理井下监测的资料,而且对于P波和S波信号有要求,因为是基于初至时取的定位算法,对于有些油田压裂过程中P波信号较弱或甚至不可见初至的情况下,不能进行实时监测
    发表于 2014-9-15 18:48:28 | 显示全部楼层
    发表于 2014-9-15 18:48:56 | 显示全部楼层
    发表于 2014-9-15 19:09:30 | 显示全部楼层
    GMT+8, 2025-5-13 04:04 , Processed in 0.051702 second(s), 23 queries .
