查看: 1903|回复: 5
Casing drilling technology
  • 签到天数: 71 天
    发表于 2012-1-28 01:46:26 | 显示全部楼层 |阅读模式
    17_CASING_DRILLING_TECHNOLOGY.pdf (1.83 MB, 下载次数: 732)
    Abstract
        Casing drilling is an alternative option to conventional drilling and uses standard oilfi eld casing instead of drillstring. This technology is one of the greatest developments in drilling operations. Casing drilling involves drilling and casing a well simultaneously.
        In casing driling process, downhole tools can be retrieved, through the casing on wire-line, meaning tool recovery or replacement of tools can take minutes versus hours under conventional methods. This process employs wireline-retrievable tools and a drill-lock assembly, permitting bit and BHA changes, coring, electrical logging and even directional
    or horizontal drilling. Once the casing point is reached, the casing is cemented in place without tripping pipe.
  • 签到天数: 436 天
    发表于 2012-1-28 14:44:14 | 显示全部楼层
  • 签到天数: 501 天
    发表于 2012-2-10 10:00:37 | 显示全部楼层
    SPE论文还是...
  • 签到天数: 80 天
    发表于 2012-3-30 00:15:25 | 显示全部楼层
    啊,全英文的啊。好资料吧!~~
  • 签到天数: 80 天
    发表于 2012-3-30 00:15:46 | 显示全部楼层
    要是是中文版的就最好了,呵呵
  • 签到天数: 58 天
    发表于 2013-12-13 16:57:12 | 显示全部楼层
    谢谢能分享资料。
    GMT+8, 2025-4-24 19:13 , Processed in 0.118253 second(s), 26 queries .
