查看: 2033|回复: 0
[技术讨论] Horizon parallel or stratal slicing-如何选择切片技术?
发表于 2012-1-11 08:37:22 | 显示全部楼层 |阅读模式
摘录一段The Geological Society special publication: Seismic Geomorphology: Applications  to Hydrocarbon Exploration and Production ,Seismic  geomorphology-  an  overview  一文中关于如何选择切片技术的文字(作者:H. W.  POSAMENTIER, R.  J.  DAVIES,  J. A.  CARTWRIGHT &  L. WOOD),对大家肯定有帮助,没来得及翻译,但是我想大家都能看懂:
Horizon parallel  or  stratal slicing.
Several  tech-niques exist  for  slicing through  a  3D seismic data volume.  They  include time  slices,  dipping planar slices, horizon-parallel  slices  (i.e. stratal  slices),  and proportional  slices. Commonly,  when  looking for stratigraphic  features,  the best  results  are obtained by  slicing  as near  as  possible to  the  target interval  and  parallel to  a  well-mapped structural  horizon. This  technique will  reduce  the affects  of  structuring that  might obscure  the  imaging of  palaeo-geomorphic  features. Where  seismic reflections  are  parallel and nearly  horizontal,  then seismic  time  slices would suffice  (Figs  4 and  5a). Where  reflections are uniformly  dipping,  then dipping  planar  slices are appropriate  (Fig.  5 b). Where reflections  are  characterized  by variable dip,  then horizon parallel or horizon  slices (i.e.  stratal  slices) yield  the  best results (Fig.  5c).  In those  instances  where reflections  are  uniformly divergent,  then proportional  slicing would be  ideal. This involves slicing between  two  non-par-allel reflections,  whereby  the interval  between  the  two  reflections is  proportionately  divided into  an equal  number of  slices  (Fig. 6).
通过G&G软件中提供几种切片技术,可实现上述切片类型:
time  slices在三维地震数据体中,直接沿某个时间切片出时间切片;
dipping  planar slices:使用自由切片工具可以切出任何倾斜角度的切片;
horizon-parallel  slices使用沿层切片工具;
proportional  slices使用层段切片模型可实现等比例切割地指定层段。
层段切片:当需要计算某两个参考层之间层段的统计属性时,可事先在两层之间制作层段切片,然后再进行统计计算。
层段切片
沿层切片
G&G软件试用咨询:2578471087
详情:www.geogeo.com.cn
GMT+8, 2026-7-12 18:23 , Processed in 0.055312 second(s), 27 queries .
