查看: 6958|回复: 48
【理论】低渗透油藏非线性渗流理论及在油藏数值模拟的应用
  • 签到天数: 18 天
    发表于 2012-1-7 16:51:51 | 显示全部楼层 |阅读模式
    【题名】Non-linear Flow Theory of Low Permeability Reservoir and Its Preliminary Application in Numerical Simulation
    【格式】PDF
    【页数】6页
    【预览】
    Abstract: In order to describe the percolation law in low permeability reservoir, the correction factor of percolation ability which varies with the pressure gradient is proposed in this paper on the basis of experiment. The nonlinear flow model is developed for the low permeability reservoir and is applied to the black oil model stimulator. The result of the preliminary simulation conforms to the field data well.
    From the calculation result, it is shown that the correction factor of percolation ability is larger around the production and injection wells where the pressure gradient is larger, and it is smaller in the area far from the connecting line of the production and injection wells.
    Key word: low permeability reservoir, nonlinear porous flow, numerical simulation
    国内专家著作,搞低渗透渗流机理及数值模拟研究方向的很好的参考资料。
    【下载】
  • 签到天数: 74 天
    发表于 2012-1-7 16:55:03 | 显示全部楼层
    看看
  • 签到天数: 640 天
    发表于 2012-1-7 16:57:49 | 显示全部楼层
    发表于 2012-1-7 18:25:35 | 显示全部楼层
    牛 牛
  • 签到天数: 502 天
    发表于 2012-1-7 22:18:11 | 显示全部楼层
    学习以下
    发表于 2012-2-20 09:16:55 | 显示全部楼层
    发表于 2012-5-7 17:04:37 | 显示全部楼层
    看看!~~
  • 签到天数: 4 天
    发表于 2012-7-5 14:23:03 | 显示全部楼层
    走过路过看看
  • 签到天数: 239 天
    发表于 2012-7-12 08:46:28 | 显示全部楼层
    闭门造车,无病呻吟
  • 签到天数: 484 天
    发表于 2012-7-12 13:23:03 | 显示全部楼层
    看一下,感谢!
    GMT+8, 2026-6-7 08:23 , Processed in 0.041406 second(s), 22 queries .
