查看: 1712|回复: 1
Stabilizing boreholes while drilling reactive shale
  • 签到天数: 71 天
    发表于 2012-1-5 03:39:15 | 显示全部楼层 |阅读模式
    Stabilizing boreholes while drilling reactive shale.pdf (124.71 KB, 下载次数: 9)
       SILICATE-BASED DRILLING fluids have been used to drill successfully1,2 through a wide range of troublesome shales in various parts of the world. With the advent of stringent environmental regulations and foreseen phasing out of oil-based and synthetic-based drilling fluids, current petroleum industry efforts are focused towards finding alternate environmentally acceptable water-based drilling fluids.
        With this in view, silicate-based systems are being used extensively in the oil and gas well drilling industry. Silicate-based fluids are therefore replacing oilbased/ synthetic-based muds (OBM/SBM) in a wide range of applications where troublesome clay-bearing formations such as shales and claystones are to be drilled. The mechanisms by which OBM/SBM inhibit the hydration of
    shales have been reviewed here, as is the failure of common water-based muds (WBM) to duplicate the success of OBM/SBM in drilling these troublesome formations.
  • 签到天数: 74 天
    发表于 2012-1-5 08:53:23 | 显示全部楼层
    看着英文好纠结啊,如果有点汉语介绍就好了
    GMT+8, 2025-5-9 23:04 , Processed in 0.088619 second(s), 26 queries .
