查看: 11829|回复: 60
【结束】[散阳光币]热烈祝贺liyongph发SCI文章收录于petroleum science并分享经验
   关闭 [复制链接]
  • 签到天数: 218 天
    发表于 2011-10-28 08:39:36 | 显示全部楼层 |阅读模式
    论文题目:碳酸盐岩油气藏储集体类型划分方法研究
    论文题目(英文):Classification of carbonate gas condensate reservoirs using well test and production data analyses
    作者:李勇,李保柱,胡永乐等
    刊物名称:石油科学
    刊物名称(英文):petroleum science(PETROL SCI)
    影响因子:0.432
    摘要:碳酸盐岩储集体类型对油气井的生产动态起着绝对的控制作用,以前多采用静态方法进行划分,但结果常与实际生产动态不符。文章提出了采用试井及生产分析典型曲线特征对储集体类型进行划分的方法。以中国塔里木油田塔中I号气田为例进行研究,对碳酸盐岩油气藏储集体类型划分方法进行了研究。根据不同储集体类型的试井及Blasingame方法典型曲线特征不同,建立了试井及Blasingame方法典型曲线与储集体类型的对应关系,将储集体类型划分为3大类7小类,并采用生产动态进行验证。基于储集体类型划分基础上,进一步开展提高采收率攻关,对其中3口挥发性油井开展了单井注水替油试验,实施效果较好
    Abstract:
    Carbonate reservoir patterns play an important role in the production performance of oil and gas wells, and it is usually classified through static data analysis which cannot reflect the actual well performance. This paper takes the Tazhong No. 1 gas field in the Tarim Basin, China as an example to investigate the classification of carbonate reservoirs. The classification method mainly combines well test analysis with production analysis
    especially the Blasingame type curve method. Based on the characteristics of type curves for well test analysis and the Blasingame method, the relationship between the type curves and reservoir pattern was established. More than 20 wells were analyzed and the reservoirs were classified into 3 major patterns with 7 sub-classes. Furthermore, the classification results were validated by dynamic performance analysis of wells in the Tazhong No.1 gas field. On the basis of the classification results, well stimulation
    water flooding in a single well―
    was carried out in three volatile-oil wells, and the oil recovery increased by up to 20%.
    论坛用户名:liyongph
    文章发表在2011年第一期,今年5-6月左右出版的
    经验分享:
        由于是英文期刊,投稿时候同时提交了中文稿及英文稿,虽然要求可以先选择投英文稿。本人在此期刊已经发表过两篇文章,均采用同时提交中英文稿,录用率较高。
        文章版面格式参考之前期刊的版面格式,文字风格等,图标设计尽量美观,如表格设计为三线格格式等。让审稿专家阅读起来较方便,同时使专家或者编辑一看到稿子就觉得您是有写稿经验的人,不能让编辑或专家觉得你像是个新手。尤其参考文献的地方,不同期刊、书、论文等引用的方式要准确。
        文章摘要要精简简练并体现出文章的精华,可以参考EI或者SCI摘要写作要求等(网上可查阅)。
        剩下的就是文章内容部分了,这个与自己的研究有关了,尽量体现出新意来。没法提具体建议了。
        还有就是通篇文字要顺畅,不能语句不通或错别字太多。我每写一篇稿子最后都是要通读几遍再看看有没有错误的。
        最后就是SCI的期刊一般都是英文的,不要怕自己的英文水平差。英文稿一般肯定都是要修改几遍的。我每次的英文稿都是来回返工5-6遍的,英文稿编辑都会帮忙修改,如果编辑不懂的地方就让你自己修改。最后编辑也会再让国外的专家再通读一遍看看是不是用词恰当的,因此不要担心自己的英语不行,有他们会帮你搞定的。
    热烈祝贺阳光石油论坛会员liyongph发SCI文献一篇,阳光石油论坛散阳光币500,奖励liyongph阳光币100,大家在楼下回复。每楼阳光+10,散完为止。每个会员加阳光币一次,不要重复抢楼哦。
  • 签到天数: 218 天
     楼主| 发表于 2011-10-28 08:40:13 | 显示全部楼层
    自己占坑种萝卜先
  • 签到天数: 12 天
    发表于 2011-10-28 08:42:18 | 显示全部楼层
    恭喜楼主,顶~~~~~~~~~~~~~·
    参与人数 1阳光币 +10 收起 理由
    岱海青蓝 + 10
  • 签到天数: 137 天
    发表于 2011-10-28 08:46:49 | 显示全部楼层
    听说这个审稿特别慢,不知是不是这样
    参与人数 1阳光币 +10 收起 理由
    岱海青蓝 + 10
  • 签到天数: 455 天
    发表于 2011-10-28 09:09:00 | 显示全部楼层
    我要金币啊
    参与人数 1阳光币 +10 收起 理由
    岱海青蓝 + 10
  • 签到天数: 141 天
    发表于 2011-10-28 09:15:24 | 显示全部楼层
    堆起楼来~占其位~
    参与人数 1阳光币 +10 收起 理由
    岱海青蓝 + 10
  • 签到天数: 78 天
    发表于 2011-10-28 09:27:30 | 显示全部楼层
    恭喜恭喜啊 我要阳光币啊
    参与人数 1阳光币 +10 收起 理由
    岱海青蓝 + 10
  • 签到天数: 640 天
    发表于 2011-10-28 09:31:18 | 显示全部楼层
    恭喜恭喜啊,祝贺!!!
    参与人数 1阳光币 +10 收起 理由
    岱海青蓝 + 10
  • 签到天数: 71 天
    发表于 2011-10-28 10:11:17 | 显示全部楼层
    恭喜恭喜
    参与人数 1阳光币 +10 收起 理由
    岱海青蓝 + 10
  • 签到天数: 109 天
    发表于 2011-10-28 10:30:20 | 显示全部楼层
    祝贺发文章,恭喜发文章
    参与人数 1阳光币 +10 收起 理由
    岱海青蓝 + 10
    GMT+8, 2026-7-7 09:59 , Processed in 0.068573 second(s), 34 queries .
